strange reflections after "resume render"
Come here for help & support.
tornello
Post by tornello » Mon Nov 10, 2014 9:38 pm
tonight I have done a rendered and it was all ok!
This morning I have opened Indigo and then:
1) I have opened the igs scene file,
2) then I have resumed render from the igi file
the result is a strange effect of reflections everywhere as you can see in the image
Can you help me? :?
Re: strange reflections after "resume render"
Post by Zom-B » Mon Nov 10, 2014 9:48 pm
For me this looks like you resumed the scene with a lower resolution!
If you take a closer look, you'll see that Indigo rendered smaler on top of your rendering...
The question is now why that happened?
Did you maybe changed the resolution inside Indigo GUI during the first render session, and have not saved this changes back to the IGS ???
Please double check the resolution.
Also a quick restart of the main render for 5min, then save IGI and resume, to see if this happened again, just to be sure it doesn't, would be great!
tornello
Post by tornello » Mon Nov 10, 2014 10:09 pm
Hi, thanks for the answer.
Could it have been the IGS supersampling factor different form the IGI supersampling factor?
I will make some testes in these days.
Can I write you again in the next days?
Zom-B wrote:For me this looks like you resumed the scene with a lower resolution!
Post by Zom-B » Mon Nov 10, 2014 10:13 pm
tornello wrote:Could it have been the IGS supersampling factor different form the IGI supersampling factor?
Yes, changing the Super Sampling does change the internal resolution! Changing it on resume is very likely to end up like your scene!
tornello wrote:I will make some testes in these days.
Fell free to test & post whenever you have some time :)
tornello
Post by tornello » Mon Nov 10, 2014 10:15 pm
ok thank you very much for your kindness,
I will do the tests!
:D
Post by pixie » Tue Nov 11, 2014 7:53 am
I think we have here a quite clear case of paranormal virtuality. Dimensions are clearly melting and becoming one towards the infinity.... :shock:
tornello
Post by tornello » Tue Nov 11, 2014 7:58 am
:mrgreen:
pixie wrote:I think we have here a quite clear of
Post by CTZn » Tue Nov 11, 2014 10:50 am
hi there, I'll hijack the thread somewhat to report a similar and unexpected behaviour I experienced today while resuming a render; in short, the scene name into the igi changed to a different, most recent scene name that I had to remove from disk so I could point manually to the original scene file. I did load the igi alone to play with tone mapping in between, but for the life of me I don't reckon I saved it outside of a rendering context. No harm done since Indigo was set not to save igi automatically.
Post by pixie » Wed Nov 12, 2014 7:52 am
I can confirm I have the same behavior
tornello
Post by tornello » Wed Nov 12, 2014 7:54 am
Hi!
Did you change resolution?
kklors
Post by kklors » Wed Nov 12, 2014 11:59 am
This is actually a pretty dope effect : O
Juju
Post by Juju » Wed Nov 12, 2014 11:29 pm
*microsoft spindoctor* undocumented feature
galinette
Post by galinette » Thu Nov 13, 2014 12:25 am
It's clearly not a resolution issue. In the image sent by pixie, the camera viewpoint before and after resume is different. The result from two different cameras is superimposed.
Maybe you changed the camera interactively in Indigo, and resumed the scene without having saved it with the new camera parameters?
Eclat-Digital Research
http://www.eclat-digital.com
Post by lycium » Thu Nov 13, 2014 1:12 am
I think galinette is right on the money again :)
This thread is pretty strong evidence that we should (optionally?) pack the scene file into an IGI file for easy / error-free resuming.
thesquirell
Post by thesquirell » Thu Nov 13, 2014 2:10 am
I think that pixie said yesterday on the chat something like "i had multiple files in a queue, and now, whenever i want to resume one they got mixed", so the difference in the angles in the render can come from overlapping different files, i guess. :) Ono-Sendai tried resuming renders from queue, and it worked for him, so I'm guessing this is a localized error. As for the glitch in the first post, no idea, nobody is reporting! :D
