I have an important question..
I need to reinstall Windows Seven on my computer. I wanted to know if I do that, will I loose all my rendering settings, texture effects, bump maps, materials type, etc etc ? Or is it saved into the sketchup file just as the texture files are ?
Its very important that I know all I have to know before reinstall my computer, because with all the time I spended on all my scenes the last 3 years, I will be very bad if I lost every parameters...
Please ?
Render settings
Re: Render settings
Hi Onizuka,
Settings are generally stored in the SketchUp file.
Watch out for backing up external (linked) Indigo materials though!
Re: Render settings
Thanks for your answer ! Ok for the linked materials then.
So after reinstalling windows, when I will put my files on my computer again, reinstall indigo, etc etc, I will have all my parameters ?
Re: Render settings
Yes, you should do.Onizuka wrote:Thanks for your answer ! Ok for the linked materials then.
There's an easy way to test this - move your SketchUp files to another computer and see if they work.
Re: Render settings
Ok I will test that ! Thanks a lot Onosendai
Re: Render settings
Should I also save the files "roaming/indigo renderer", in wich are all the textures, the renders automatcly saved, etc ? Or is this part also into the sketchup files ?
