Blendigo 3.8.5.0
8 posts • Page 1 of 1
Blendigo 3.8.5.0
Post by fused » Sat Jul 12, 2014 12:48 am
Archive: http://downloads.indigorenderer.com/dis ... .8.5.0.zip
Windows Installer: http://downloads.indigorenderer.com/dis ... taller.exe
Changelog:
3.8.5.0
* Added arch glass option to specular material.
* Fixed particle export being slow.
* Fixed background rotation.
* Fixed parent visibility being ignored.
* When exporting animations, frames have a random seed, seeded by frame number.
Bug reports and comments welcome!
fbrunell
Re: Blendigo 3.8.5.0
Post by fbrunell » Sat Jul 12, 2014 6:10 am
Hello, I tried to install the zip file but got the following error messages. Could it be because I'm using version 2.7.0 of Blender?
File "C:\blender-2.70-windows64\2.70\scripts\modules\addon_utils.py", line 278, in enable
imp.reload(mod)
File "C:\blender-2.70-windows64\2.70\python\lib\imp.py", line 252, in reload
return module.__loader__.load_module(name)
File "<frozen importlib._bootstrap>", line 586, in _check_name_wrapper
File "<frozen importlib._bootstrap>", line 1023, in load_module
File "<frozen importlib._bootstrap>", line 1004, in load_module
File "<frozen importlib._bootstrap>", line 562, in module_for_loader_wrapper
File "<frozen importlib._bootstrap>", line 869, in _load_module
File "<frozen importlib._bootstrap>", line 313, in _call_with_frames_removed
File "C:\Users\frederic.brunelle\AppData\Roaming\Blender Foundation\Blender\2.70\scripts\addons\indigo\__init__.py", line 48, in <module>
imp.reload(core) #@UndefinedVariable
File "C:\Users\frederic.brunelle\AppData\Roaming\Blender Foundation\Blender\2.70\scripts\addons\indigo\core\__init__.py", line 61, in <module>
from indigo.core.util import getVersion, getGuiPath, getConsolePath, getInstallPath, count_contiguous
ImportError: cannot import name count_contiguous
EDIT : Flushed Blender directory, reinstalled (version 2.71) and installed blendigo 3.8.5 and it worked fine.
aleksandera
Post by aleksandera » Sat Jul 12, 2014 7:32 am
I confirm, particles are a lot faster. Thx! :D
kklors
Post by kklors » Sat Jul 12, 2014 9:22 am
: OO This looks awesome aleksandera!
Post by StompinTom » Mon Jul 14, 2014 9:45 am
Particle speedup works great!
Still only exporting visible particles, though... Any way to export full particle amount?
EDIT: Particle export also doesn't seem to work when the Display mode is set to Points (instead of Render). Could these two be related issues?
Post by StompinTom » Mon Jul 14, 2014 5:07 pm
Bug: when Camera is set to Orthographic, it throws "local variable 'ws' referenced before assignment".
Post by fused » Tue Jul 15, 2014 12:47 am
StompinTom wrote:Bug: when Camera is set to Orthographic, it throws "local variable 'ws' referenced before assignment".
Oops, fixed :)
StompinTom wrote:Particle speedup works great!
It seems this has been possible for a while now. Added it for the next release :)
https://code.google.com/p/blendigo/source/detail?r=55
Indigo unfortunately can't really render points, it needs some kind of geometry at least.
Post by StompinTom » Tue Jul 15, 2014 2:01 am
Oops, fixed :)
The points display mode is just to keep the viewport light, still need to export the geometry.
Still hoping for some kind of point rendering someday :D
