A natural situation
yonosoy
Re: A natural situation
Post by yonosoy » Fri Apr 11, 2014 1:28 pm
The basic problem for this setup cams is the focal length. Needs to be a shorter value (there's no meaning in a tele-macro...).
So, when AD was tested once and again the solution is blurred. Also a low F-stop is required.
Then this is a diagram of a non proper setup:
Blind because monitors since september maybe...
This one was taken from 12mm of heigth with a film of 1mm ,a focal lenght of 1.03, a F-stop of 3 (interested in nanofilms 1mm is the lowest value possible). Other setups gives a more intense AD.
Now is possible to see...
The pigs if someone is interested (6k spp)
bronces_A(final).pigs
(438.81 KiB) Downloaded 427 times
fenerolina
Post by fenerolina » Mon Apr 14, 2014 3:47 am
Hola Yonosoy, gracias por tus mensajes lisergicos!
De correcciones, la historia necesita mas de una, asi que bien por YosEidan.
Me gusta el concepto de que se construya tanto; y no hablo solo de ahora que esta mas enfocado a especular, sino que se ha hecho por la pervivencia de las ideas de unos, por ego o miedo.
Imaginarme a un profeta andando en los troncos a toda prisa como el hamster que al final no ve la rueda, me hace mucha gracia. Es genial!
Post by CTZn » Tue Apr 15, 2014 8:37 pm
i'm loving tms, even though they come blurred as you explained.
the mystical caged man gives me the creeps though, i may read more at some point and see if i can become more familiar with the concept.
keep up with the good work yonosoy !
yonosoy
Post by yonosoy » Wed Apr 16, 2014 10:32 am
yonosoy
Post by yonosoy » Sat Apr 19, 2014 7:47 pm
Hi, without problems.
Thanks Zeitmaster. Hi.
Post by zeitmeister » Mon Apr 21, 2014 7:59 pm
Nice flare! Never thought of painting obstacle maps by myself...
Grüsse, zeiti
yonosoy
Post by yonosoy » Wed Apr 23, 2014 6:09 pm
Better feelings ...
Hi again Zeitmeister. More beautiful with obstacle! The intention to draw custom maps is very old but the situation didn´t allow the try (to photograph after drawing in a paper...).
Nice inversion a digital tablet (the less expensive one).
working ...
working ...
yonosoy
Post by yonosoy » Thu Apr 24, 2014 4:52 pm
Hi again.
Fantastic shot with the inclusion of clouds (at least here ...).
Will try to synthesise this in a rig whit the inclusion of a variant of the actual cloud shader (maybe a week).
Will run to convergence but at this point is interesant. Lightroom denoise first and impulse noise reduction from rawtherapee later (worked in tiff 16-bit). Advantix-400CDs as tonemapping.
Edit: remebering... before to share the rigs is important to adapt the code with LOD for the FBMs, and actually i´m not able ...
FakeShamus
Post by FakeShamus » Fri Apr 25, 2014 12:52 am
These are gorgeous.
Just let them render longer! And are the images enlarged for some reason? I just want to see them super clean.
edit:
nevermind about the enlargement comment I was viewing them on an ipad and they were being blown up on screen for some reason.
Post by Oscar J » Fri Apr 25, 2014 1:43 am
This last one! <3
Post by CTZn » Tue Apr 29, 2014 3:16 am
i can adapt the octaves code with no problem, only that i'm not connected everyday. float octaves only work with multifractal atm if i'm correct.
yonosoy
Post by yonosoy » Tue Apr 29, 2014 6:15 pm
Zenith 88.3, 5.3K spp.
Thanks for the strong demand (not super clean for the chromatic). Super clean for the next try, this is a metropolis test ...
So glad to hear you Oscar, thanks a lot.
CTZn will be great to serve you as tester when you come back. Meanwhile...
The most exciting part is that the pigs is about 4KB of weight.
BW from agfapan-apx-400CD
dscs315_6
Polinalkrimizei
Post by Polinalkrimizei » Tue Apr 29, 2014 7:21 pm
You WIZZARD!!!
that has to be the most beautiful and fascinating 4KB ever... I might try to render a bigger resolution as soon as I'm free, and put it on my wall.
Holy sh :!: t that is amazing...
Post by StompinTom » Wed Apr 30, 2014 9:45 pm
Polinalkrimizei wrote:You WIZZARD!!!
+1 Could go with a print of that last one :)
bubs
Post by bubs » Wed Apr 30, 2014 11:06 pm
Stunning :shock:
