Indigo Renderer 3.6.26 - 3.6 Stable Release Candidate
15 posts • Page 1 of 1
Post by OnoSendai » Tue Nov 12, 2013 12:40 pm
Hi All,
This is a release candidate for 3.6 stable. This means that if there aren't any major bugs found in this build, this build will become the 3.6 stable build.
Please test!
Indigo for Windows 32-bit:
IndigoRenderer_3.6.26_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.6.26_Setup.exe
Indigo for Linux 32-bit:
IndigoRenderer_v3.6.26.tar.gz
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.6.26.tar.gz
Indigo for Mac OSX (10.6 - 10.8 ):
IndigoRenderer3.6.26.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.6.26_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.6.26_Setup.exe
Indigo RT for Linux 32-bit:
IndigoRT_v3.6.26.tar.gz
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.6.26.tar.gz
Indigo RT for Mac OSX (10.6 - 10.8 ):
IndigoRT3.6.26.dmg
Changelog:
3.6.26
* Updated bundled SkIndigo installer to 3.6.25.3.
SaphireS
Re: Indigo Renderer 3.6.26 - 3.6 Stable Release Candidate
Post by SaphireS » Wed Nov 13, 2013 6:21 am
Great! Any hints on how you're planning to celebrate the release? ;)
Like a competition or something?
Post by OnoSendai » Wed Nov 13, 2013 10:29 am
SaphireS wrote:Great! Any hints on how you're planning to celebrate the release? ;)
A competition sounds like a good idea :)
Anyone have suggestions for a topic/theme?
Juju
Post by Juju » Wed Nov 13, 2013 11:24 pm
how about devising a method whereby the entrant should demonstrate as many of the new features as possible?
Post by fused » Wed Nov 13, 2013 11:33 pm
Juju wrote:how about devising a method whereby the entrant should demonstrate as many of the new features as possible?
I quite like that idea :)
Tankin
Post by Tankin » Sat Nov 16, 2013 8:23 pm
So I installed 3.6.26 on my Windows7 master and Ubuntu 10.04 slaves and am now getting the following from my slaves:
Connected to master.
Connection Exception: Server doesn't accept protocol version, client protocol too old. (client protocol version: 12)
Connection to master terminated.
I probably need to update ubuntu or something but thought I should check here as well.
Thanks for any help.
Tankin
Post by Tankin » Mon Nov 18, 2013 3:00 pm
I also meant to mention that on the ubuntu slaves, indigo is listing its version as 3.6.12 in the GUI and at the top of the network slave
here's the whole bit from the slave (with ~)
Executing '-h 192.168.~.~ -n s'
Indigo Renderer v3.6.12, Linux 64-bit build.
Licence verified.
Licence type: Indigo 3.x Node.
Licensed to '~~~~'
Waiting for a master.
Attempting to connect to master at 192.168.~.~:7777...
Connection Exception: Server doesn't accept protocol version, client protocol too new. (client protocol version: 12)
and repeats
(3.4.18 has been running without an issue)
Thanks again
Post by fused » Tue Nov 19, 2013 2:14 am
Tankin wrote:I also meant to mention that on the ubuntu slaves, indigo is listing its version as 3.6.12 in the GUI and at the top of the network slave
Licence verified.
Licensed to '~~~~'
and repeats
Thanks again
Hi Tankin,
3.6.12 is a little outdated. Did you download 3.6.25 and it shows as .12 nevertheless?
Ideally you would be running the same version on the master and slave computers.
Regards,
Yves
Tankin
Post by Tankin » Tue Nov 19, 2013 2:47 am
Yeah I downloaded the linux 64 package from the download page
http://www.indigorenderer.com/download-indigo-renderer
its saying 3.6.26 on the tar ball and extracted folder but says 3.6.12 as described when ran.
Tankin
Post by Tankin » Tue Nov 19, 2013 2:49 am
Should I try 3.6.25?
Post by fused » Tue Nov 19, 2013 3:13 am
Tankin wrote:Should I try 3.6.25?
Sorry, that was a typo. I meant 3.6.26.
Seems like there is some problem with out linux distribution then. I will look into this right now.
Post by fused » Tue Nov 19, 2013 4:39 am
fused wrote:Sorry, that was a typo. I meant 3.6.26.
Hi Tankin,
I couldn't find any problems with the Indigo 3.6.26 linux distribution so far.
Can you try this:
> cd ~/Downloads
> wget http://downloads.indigorenderer.com/dist/beta/IndigoRenderer_x64_v3.6.26.tar.gz
> tar -zvxf IndigoRenderer_x64_v3.6.26.tar.gz
> cd IndigoRenderer_x64_v3.6.26
> ./indigo_console -v
This should download and unpack Indigo Renderer and then print the version.
To test-run the network slave (in the same directory):
> ./indigo -n s
Let me know how this goes for you.
Regards,
Yves
Tankin
Post by Tankin » Tue Nov 19, 2013 4:43 am
I'll test this later tonight and get back to you.
Thanks for the help.
Tankin
Post by Tankin » Wed Nov 20, 2013 5:42 am
So "-v" is sending out the version fine on the corrupt install in console mode but brings up the gui with version 3.6.12 displayed when ran non-console
I re-downloaded the package and tried a run in a fresh folder, as suggested, with the same results.
I did not download the tar.gz directly thru ubuntu onto the slave as I need to get a replacement wireless card, so it is possible Windows is corrupting the tarball.
I was able to get the network slaves running without a hiccup in console mode and they are plugging away right now, but anytime that I use the non-console indigo I seem to be stuck in 3.6.12
LukeAD
Post by LukeAD » Tue Apr 01, 2014 9:58 am
Getting this error message when loading SketchUp Pro 2014 after installing 3.6.26 version. Any ideas?
Error Loading File C:/Users/lukead/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb
Error: #<SyntaxError: C:/Users/lukead/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/ObjectEditor.rb:261: syntax error, unexpected ':', expecting keyword_then or ',' or ';' or '\n'
when Sketchup::ComponentInstance:
C:/Users/lukead/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/ObjectEditor.rb:263: syntax error, unexpected keyword_when, expecting keyword_end
when Sketchup::Group:
C:/Users/lukead/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/ObjectEditor.rb:263: syntax error, unexpected ':'
C:/Users/lukead/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/ObjectEditor.rb:349: syntax error, unexpected keyword_end, expecting end-of-input
end #class
C:/Users/lukead/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:12:in `load'
C:/Users/lukead/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:12:in `<top (required)>'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `require'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `load'
C:/Users/lukead/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo.rb:19:in `register_extension'
C:/Users/lukead/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo.rb:19:in `<module:SkIndigo>'
C:/Users/lukead/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo.rb:4:in `<top (required)>'
Users browsing this forum: No registered users and 190 guests
