Hello,
This is just a small update to fix a crash in an unusual circumstance - recursively defined components.
This is a beta release - please test. Please install Indigo 3.6.23 or newer before this version. Get it from here: http://www.indigorenderer.com/forum/vie ... =1&t=12606
To Install:
1) Download RBZ file from link below
2) In SketchUp, go to Window->Preferences->Extensions
3) Uncheck the SkIndigo checkbox, press OK, restart SketchUp
4) In SketchUp, go to Window->Preferences->Extensions->Install Extension
5) Select the RBZ file you downloaded
6) Check the SkIndigo checkbox again.
7) Restart Sketchup again.
NOTE: this elaborate process is to make sure the asset files get updated properly, which doesn't work if the extension is enabled.
Changelog:
#Version 3.6.25.2
#Fixed infinite loop causing SketchUp crash when exporting recursive components.
Download: http://downloads.indigorenderer.com/dis ... 6.25.2.rbz
SkIndigo 3.6.25.2 (beta)
SkIndigo 3.6.25.2 (beta) bug?
I jumped from 3.4.19 to 3.6.25.2 beta and I have found a problem curious if it's just me
If its just me help please!
Using Indigo 3.6.25 with skindigo 3.6.25.2 & sketchup 2013 on Windows 7 64bit
when exporting from sketchup the resulting indigo scene file only contains one complete instance of any single component(the rest don't show up in the IGS file) this may be effecting groups too.
Attached are two pictures with only minor differences in the sketchup file (grass, texture changes, and view angle)
The first is from 3.4.19 will all instances of components and groups showing; the second from 3.6.25.2 has exactly one instance of each component showing.
I took another file different model with the same problem and completely exploded it so that no groups or components were left and it rendered everything so i'm certain this is a component related glitch.
Re: SkIndigo 3.6.25.2 (beta)
I'm afraid I'm having this issue too. Only 1 instance of any component being exported. This has only happened since 3.6.25.2 fr me...
I've reverted to 3.6.25.1 for now and things are working fine with it...
Looks like I introduced a bug. I'll revert it.
