We have a problem with our render Queue. Each time the render of the first scene is finished, Indigo crash down (it's impossible to execute several pictures without human intervention). Each scene work well alone.
We work with the 3.6.19 version, some floating node licences, and Windows 7 64bits.
Can you help us to find a solution in order to make lots of renders?
Thanks fos your feedbacks.
BUG with render Queue in 3.6.19 version => crash of Indigo
Re: BUG with render Queue in 3.6.19 version => crash of Indi
Hey Inus,
you could give Indigo 3.6.23 a try, maybe your problem has been already fixed...
Also be sure to use the latest exporters from the forum to prevent some incompatibility.
Does The crash generates some (windows) error report and maybe some minidump file that can be zipped and send to the devs?
Sending two scenes of your scenes packed as PIGS to the devs could help too, maybe the problem is in the scenes itself. (double-check if that two PIGS loaded into the render Q also crash after first is done!)
Thanks Zom-B,
I try this immediatly.
