Hdri car shadow test
13 posts • Page 1 of 1
Antonis777
Post by Antonis777 » Wed Oct 09, 2013 12:08 pm
Just testing Indigo's new shadow catcher feature. Hdri and backplate from Moofe. Sketchup model made by Irmantenis.
Re: Hdri car shadow test
Post by CTZn » Wed Oct 09, 2013 4:06 pm
Very much a nice feature !
Bosseye
Post by Bosseye » Thu Oct 10, 2013 11:51 pm
Thats great! Can you run through the process of setting this sort of scene up in sketchup please? I've never been able to figure it out.
Thanks,
Post by OnoSendai » Thu Oct 10, 2013 11:56 pm
There is a general (not SketchUp specific) tutorial here: http://www.indigorenderer.com/documenta ... s-tutorial
Post by Zom-B » Fri Oct 11, 2013 12:31 am
Seems somebody stolen the engine of that car :D
Using alpha renders you need to double the layer of the car in your 2D app, since the car is still a little transparent (longer render times, lower SuperSampling (!) and radial splatting help here!)
Post by Oscar J » Fri Oct 11, 2013 2:38 am
Perspective looks good, but the car looks a bit pale and flat for some reason. Would need some more reflections and contrast to go with the backplate I think.
Bosseye
Post by Bosseye » Fri Oct 11, 2013 3:39 am
OnoSendai wrote:There is a general (not SketchUp specific) tutorial here: http://www.indigorenderer.com/documenta ... s-tutorial
Thanks. Works! I used the photomatching in sketchup to get the car to the correct perspective (just about)
Not sure whats going on with the material on the far door pillar internally, but the concept is sound.
Couple of things:
1) I can't select the car object in its entirety to make it invisible to camera. The 'pick object' eye dropper just selects the individual components in the model, even though the entire car is its own component.
2) Might be worth adding to your tutorial that you need to save your shadow and foreground alpha images as .png files not .jpeg.....if your other users are as dumb as me, then they'll do what I did and save them as jpegs then not be able to understand why the layers won't composite in photoshop.... :lol: :oops:
Anyone got any good sources of free (no doubt low res) backplates and matching hdri files?
Antonis777
Post by Antonis777 » Fri Oct 11, 2013 4:49 am
Zom-B wrote:Seems somebody stolen the engine of that car :D
Did duplicate car layer. Hope this seems better and not flat.
Antonis777
Post by Antonis777 » Fri Oct 11, 2013 4:51 am
Bosseye:
Hope this helps: nordicfx.net
Post by Oscar J » Fri Oct 11, 2013 6:47 am
That does look better, but now the problem is that the backplate is much sharper than the car.
Antonis777
Post by Antonis777 » Fri Oct 11, 2013 6:56 am
That's correct. I increased car size in Photoshop to match nice with backplate, because I use demo indigo version (0.7 mpx output etc). Here's another angle. Don't know though how to scale (or zoom) model to have the right size according to the picture. How could I use a reference item?
Post by Pibuz » Fri Oct 11, 2013 7:25 pm
Oscar J wrote: That does look better, but now the problem is that the backplate is much sharper than the car.
The car is in movement SO it is a little blurrier :D
Antonis777
Post by Antonis777 » Fri Oct 11, 2013 10:32 pm
E' giusto...!!
Users browsing this forum: Google Adsense [Bot] and 8 guests
