The Making Of A Curtain
10 posts • Page 1 of 1
Mongoose
Post by Mongoose » Mon Apr 22, 2013 4:16 am
Hi there.. i have been trying to make a curtain for several hours and did not succeed, i don't even know if im going in the right path...
i know how to work with SU, i have been working with it for 6 yrs now, using the low grade renderer (Podium) the only problem is that i had no idea how working and changing materials work.. i need some guidance i am really new to indigo, and trying hard to understand please if someone can help me understand step by step how to make curtains, and how to understand how to work with materials and all of its benefits in indigo
thank you very much i will upload my work when ill finish rendering
Sketchup 8, Sketchup 2013 Pro
AutoCad 2013 Architectural,
indigo 3.4.16
ROG - ASUS - X79 Sabertooth
Intel I7-3930K 12 Threads
NVIDIA - GTX670 DC II
16 GB - Corsair Vengeance With Applied Cooling
Noktua NH-D-14
128 - OCZ SSD Vertex IV
Pikadili89
Re: The Making Of A Curtain
Post by Pikadili89 » Mon Apr 22, 2013 7:32 am
Making of a curtain is a little bit to confusing for a beginer so I suggest something else. Since indigo can "read" invisible background of PNG file I have little trick for you. You can take the following textile texture and delete black background in photoshop and save as PNG file. When you make new material in sketchup with that PNG file, lower the texture as it should be for curtain and apply it on your model of curtain. When you render it you will have semitransparent curtain. You can also set same values for that material as some silk material from material data base on this site. Hope I helped! :)
Mongoose
Post by Mongoose » Mon Apr 22, 2013 7:37 am
Yes it might be itbut as a newby tothis awsome and unique renderer i dont even succeed using silk, ill try what u said and try to aply it to my own thank you so much
indigo 3.4.16
Noktua NH-D-14
JK
Post by JK » Mon Apr 22, 2013 8:49 am
Please post the result when you'll be done :)
Mongoose
Post by Mongoose » Mon Apr 22, 2013 7:17 pm
sure-thing bro, ill upload it.. i'm such a noob but i am happy i found this forum, and you ppl
indigo 3.4.16
Noktua NH-D-14
Mongoose
Post by Mongoose » Tue Apr 23, 2013 8:40 pm
this is what i have made but there are lot's of fireflies i get that i didnt configure it correctly
my goal is to start creating more life inside the kitchen, and then move on for more rooms, to start building materials in order to get some more meat in this room thank you all for helping me so far, hope ill get more help at the future if ill need it.
indigo 3.4.16
Noktua NH-D-14
Post by Zom-B » Tue Apr 23, 2013 9:09 pm
Simply use a diffuse and blend in a Diffuse Transmitter material for 33% (tweak that value higher for more light transmitance).
No need for some microscopic holes in a texture at all :)
Dismiss the Glass of your window if it isn't visible at all for faster rendering, also give ExitPortals a try.
Some great Video Tutorials for Skindigo can be found here: http://www.youtube.com/playlist?list=PLD14E96A2CD263FE1
Mongoose
Post by Mongoose » Tue Apr 23, 2013 9:19 pm
1st of all thank you very much,
2nd i know that guy he is supergreat i learned some things fcrom his videos but sometimes he lacks of explaining how he got his presets, such as the direct material, or component, i will look up some of his work in order to get better on edditing
Edit:
Btw i saw its "Whaat" lolz he is awsome
indigo 3.4.16
Noktua NH-D-14
Post by Pibuz » Wed Apr 24, 2013 12:45 am
Hi mongoose!
First thing, don't refer to Podium as "low grade" :D It's very simple, so it's affordable for many users, but I've seen magic coming out of it. So my tip is not to loose it completely...
Second thing, I've learnt that detailing isn't always NEEDED.. In archviz, in most cases the curtains are a furniture thing, so you won't need to gat close views of those. I usually simply put a white fabric texture in the diffuse channel (sketchup color); the base geometry can be single sided too, not necessarily a volume. Then, I set the material to have opacity=20% or so. Before launching the render, make sure the SkIndigo material is DIFFUSE, not specular.
The banner render's curtain is done like this. 8)
Mongoose
Post by Mongoose » Wed Apr 24, 2013 12:54 am
oh i get it.. i had it all on Specular, i guess its the thing with getting transparency equal to your sketchup material, i will try it then...
i was using podium for about 5 yrs now, since it was released i think, i was enlightened by it had some jobs
done but not something stunning, eye blowing thing, just some work and personal projects.
Train station at my country (part of the practical architecture engineering college)
Made by me 2007
i will try to apply what you said.. i am not giving up completely on podium just want a fresh start
indigo 3.4.16
Noktua NH-D-14
