here is my first try with indigo!
12 posts • Page 1 of 1
paulo_gomes
Post by paulo_gomes » Thu Feb 22, 2007 3:01 pm
i've made a couple of tests with indigo and now i'll try to do something with them.
paulo_gomes
Post by paulo_gomes » Thu Feb 22, 2007 3:12 pm
i'll lower it in my next render. thanks.
mzungu
Post by mzungu » Fri Feb 23, 2007 3:11 am
I'd love to see this same scene with the overhead light turned on, and some translucency in it's shade. It would really add some dynamics to the lighting. From an "artistic" (whatever that is :wink: ) standpoint, the scene could really use a center of interest, a subject, or a story to tell. Coming along, tho. Keep at it!
-mzungu
"The fear of the Lord is the beginning of wisdom" - Solomon
paulo_gomes
Post by paulo_gomes » Fri Feb 23, 2007 5:29 am
hi, here's an update, i've lowered the max consec rejects to 50 (thank you radiance, cleans much faster).
mzungu, thank you for the reply, i'll try to turn on the overhead light on my next render, i'll have to figure out how to make translucid material.
first i have to change the jar (i dont like it!) and mess with that flying curtain.
Kosmokrator
Post by Kosmokrator » Fri Feb 23, 2007 6:03 am
hey i see some roughnes on glass is this indigo 0.7?
nice image.... :wink:
paulo_gomes
Post by paulo_gomes » Fri Feb 23, 2007 6:30 am
yes, its modeled in blender and render indigo 07 test5. the glass is from the indigo material library
http://www.elqx.com/indmatdb/?s=Material&id=72
thank you for the reply.
eman7613
Post by eman7613 » Fri Feb 23, 2007 8:07 am
radiance wrote:good work, especially for a first...
maybe a bit too noisy though...
maybe try with max consec rejects < 100 ?
Greetz,
Radiance
paulo_gomes wrote:hi, here's an update, i've lowered the max consec rejects to 50 (thank you radiance, cleans much faster).
.... i have had that set to 1000 for everything ive done..... learn something new every day.
Yes i know, my spelling sucks
paulo_gomes
Post by paulo_gomes » Thu Mar 01, 2007 6:57 am
here's a litle update.
Post by Kram1032 » Thu Mar 01, 2007 7:31 am
Very good warm lamp light, but the chair beyond the window is a bit overexposed... can you reduce lightreflection, or is it SSSlight from back? in this case, can you increase the absorbtion? Or maybe, you have to reduce the windowlight...
Looks nice, anyway :D
paulo_gomes
Post by paulo_gomes » Thu Mar 01, 2007 2:09 pm
thank you Kram1032 for the reply, i'm still messing around with the material, the curtain was supose to be dark red, the light from the window is from the sunlight and the material from the chair is a difuse material with a texture of wood. I've fire up the bloom and the reinard in violet. I'm trying to learn how to setup material and lightning but i don't understand many things that you guys talk in the forum.
I don't know what is sss light, could you give me some hints?
I use blender with the blendigo exporter.
I would appreciate if you guys could help me make a material for the curtains and the headlight (it was supose to be white).
paulo_gomes
Post by paulo_gomes » Thu Mar 01, 2007 2:14 pm
ok, sorry i've set the color temperature of the lamp ti 2800 (incandescent) now i know how the lamp isn't white :)
Post by Kram1032 » Fri Mar 02, 2007 3:10 am
SSS light doesn't exist ;)
I meant the Material!
I thought, it's plastic with SSS (SSS = Sub Surface ScratterinG, which means, that light passes the object, but you can't see, what's behind it!
Take a peace of paper and hold it on a window! You can see that the paper is lit from behind, but you can't see, what's behind!) -> I thought, that the white light may pass through the material and isn't reflected, but transmitted
So, SSSlight means (or should mean)
Sub surface scrattered light ;)
