Cindigo Wishlist
Rich_Art
Re: Cindigo Wishlist
Post by Rich_Art » Wed Jul 18, 2012 1:10 am
An option to turn off the area light for showing the light in render. I have an area light which is in sight of the cam and it shows a black area in the image.. See attached screengrab.
Peace,
Rich_Art. :wink:
Cinema4D R13 Studio + VrayforC4D + UVLayout Pro + 3DCoat + MOI3D
[FONT=Book Antiqua]Neem ook gerust eens een kijkje in mijn galerij en op mijn Vimeo page
Post by Zom-B » Wed Jul 18, 2012 1:49 am
Rich_Art wrote:An option to turn off the area light for showing the light in render. I have an area light which is in sight of the cam and it shows a black area in the image.. See attached screengrab.
Invisible mesh emitters is Indigo related request and bought up quite some time, feel free to bump it here:
http://www.indigorenderer.com/forum/vie ... =5&t=11737
Rich_Art
Post by Rich_Art » Wed Jul 18, 2012 1:55 am
Ah ok.. well I guess it will be implemented some day. :-)
Peace,
Rich_Art. :wink:
Rich_Art
Post by Rich_Art » Fri Jul 20, 2012 1:54 am
Hi Guy's,
I have a suggestion..
There is an option to use NK data. That is nice but I miss a few thing.
The NK data is not displayed correct in the little thumb. (dark shiny is all I get)
Not all the NK data can be used. I get an error.
And it would be nice to have a pulldown menu for choosing this data as seen in Indigo renderer self.
Peace,
Rich_Art. :wink:
Post by Zom-B » Fri Jul 20, 2012 2:15 am
Hey Rich Art...
Indigo doesn't support any transparent NKs at the moment (and some other with extra data), so that is a Indigo Feature...
The black shiny thing you see is simply the black Environment that surrounds the Preview models, it renders faster then a "room scenario", but a sollution using a small EnvMap would be best here, I already asked yves for that... its on the ToDO.
The NK Dropdown is quite high on the ToDo List as far as I know ;)
Rich_Art
Post by Rich_Art » Fri Jul 20, 2012 2:35 am
That makes sense. :-)
Thanks for the reply..
Peace,
Rich_Art. :wink:
andeltoz
Post by andeltoz » Sat Jul 21, 2012 9:10 pm
In Cinema 4D on OS X, the plugin does not automatically start the application Indigo Renderer, as is the case for Windows users. You can do this?
Regards
cowagner
Post by cowagner » Sat Oct 06, 2012 11:36 pm
Hi there.
In older versions there was a possibility to render the new indigo material (i am talking from cinema 4 d)
now in the last version this isnt possible anymore. why ?
Post by fused » Mon Oct 08, 2012 6:58 am
andeltoz wrote:In Cinema 4D on OS X, the plugin does not automatically start the application Indigo Renderer, as is the case for Windows users. You can do this?
Regards
Hi andeltoz,
that should be working. There was a bug tho which was preventing the starting of Indigo in some cases that was fixed in Indigo for C4D 3.4.8: http://www.indigorenderer.com/forum/vie ... 10&t=11905
Post by fused » Mon Oct 08, 2012 6:59 am
cowagner wrote:Hi there.
Hi cowagner,
could you be a little bit more specific what the exact problem is?
Regards,
Yves
sandidolsak
Post by sandidolsak » Fri Nov 23, 2012 3:26 am
Hey, please change the "xcindigoislshader.res" to:
	GROUP ID_SHADERPROPERTIES
		SCALE_V;
		FILENAME ISL_SHADER_TEXTURE1 { }
		FILENAME ISL_SHADER_TEXTURE2 { }
		FILENAME ISL_SHADER_TEXTURE3 { }
		STRING ISL_SHADER_CODE {
			CUSTOMGUI MULTISTRING;
			SCALE_V;
so we get a nice coding field bigger then 3 lines.
Thanks =)
Post by Zom-B » Fri Nov 23, 2012 3:36 am
sandidolsak wrote:so we get a nice coding field bigger then 3 lines.
Thanks =)
Wooohoooo, finally :D
Phoenix
Post by Phoenix » Fri Jan 04, 2013 4:53 am
Zom-B wrote:The NK Dropdown is quite high on the ToDo List as far as I know ;)
Yes, since years! ;)
JH-CAD-Architekt
Problems with the Boole-Object in R10.5 to Indigo 3.4.18
Post by JH-CAD-Architekt » Wed Jan 23, 2013 1:30 am
Hello,
There seems to be a bug :oops: :
It only occurs by exporting, not by rendering in the C4D surroundings!
Can it be resolved? There has been one version, where this problem did not occur!
Thanks,
Best regards,
Johannes
Indigo-Boole-Problem.zip
The trying Szene
(217.19 KiB) Downloaded 1007 times
The resolutions in Indigo and C4D R10.5 surrounding
Post by fused » Fri Jan 25, 2013 1:24 am
thank you for reporting the problem. I will have a look at this.
