I have set enviroment map, .hdr and program report me error
Error while building scene: Error while loading diffuse material 'EnvironentMap': Failed to load texture 'G:\Tarik\HDRI\DOSCH HDRI - Nature\ddhdrin-2\VC\DH104VC.hdr': unhandled format ('G:\Tarik\HDRI\DOSCH HDRI - Nature\ddhdrin-2\VC\DH104VC.hdr
Aftter that i have change enviroment map to .exr, but it keeps reporting me same mistake.. How can i undo that, and fix problem?
Thanks a lot.
Enviroment map problem
Skindigo
- zeitmeister
Did you convert it properly to an EXR or did you simply change the suffix?
EXR should work.
Which software and versions do you use?
EXR should work.
Re: Enviroment map problem
I have export it corectly to .exr, but it shows same problem just like i didn't change it at all.. Thats the problem.. If i change enviroment, and decide to use sun instead, it still reports the same mistake..
I use sketchup 8, indigorenderer 3.2.13
Skindigo
Seems one of your materials still has a HDR assigned.tarikb wrote:I have export it corectly to .exr, but it shows same problem just like i didn't change it at all.. Thats the problem.. If i change enviroment, and decide to use sun instead, it still reports the same mistake..
And it also seems that Skindigo exports all mats to Indigo, even the unused...
So Indigo loads the mat with .hdr and reports an error.
Would be quite a RAM saver if Skindigo would only export used materials *wink*
You have to:
1. Change the environment map material to the one with EXR in the Skindigo environment dialog (Apply!)
2. Delete the material in the SketchUp material dialog (right click) which belongs to the HDR
The order is important, the other way round it will not work (the deletion will fail)
Thanks man, it really helps
What is the best way to setup enviroment map.. I mean, how to set up emission setings of material..
Skindigo
