Indigo for Cinema 4D 3.4.10b
14 posts • Page 1 of 1
Post by fused » Fri Oct 19, 2012 2:03 am
wlf_alex
Re: Indigo for Cinema 4D 3.4.10b
Post by wlf_alex » Fri Oct 19, 2012 3:26 am
Yes, it's fixed !!! :D
Thanks Yves for your excellent job !!!
wlf_alex
Post by wlf_alex » Wed Oct 24, 2012 12:21 am
Hola Yves !
Another small bug :
I use SurfaceSpread for scattering of objects on the surface. To reduce the number of objects in viewport of cinema 4d i change Editor Weight parameter. Cindigo render works correctly,
but render with indigo shows wrong number of objects that equals the viewport number of objects.
Could you please fix the problem if possible ?
(attached scene file)
scattering test.rar
(175.84 KiB) Downloaded 331 times
Post by zeitmeister » Wed Oct 24, 2012 3:06 am
Hm,
don't have the plugin here at work... will test it at home tonight.
Lower editor resultion works fine with MoGraph instances... strange.
[EDIT]
Ah, you are using the editor weight within the pugin!
Never tested that, but FastFur f.e. works fine with Indigo...
[/EDIT]
Post by fused » Wed Oct 24, 2012 10:37 pm
Interesting... Looking into it.
Post by fused » Wed Oct 24, 2012 11:11 pm
This doesn't seem to be my fault.
The SurfaceSPREAD generator object does not generate the geometry for an external render when it's asked to do so.
You can also see this when you select the SurfaceSPREAD object and press 'C' (convert). It will only generate the editor representation (although it should generate the render representation).
wlf_alex
Post by wlf_alex » Wed Oct 24, 2012 11:55 pm
I see...
Thanks a lot, Yves !
Post by zeitmeister » Thu Oct 25, 2012 10:18 pm
Hehe, you should bug Jack to solve this issue...
c4d-jack
Post by c4d-jack » Mon Oct 29, 2012 10:41 pm
Nah, not my bug either ;-)
When generating the clones, I check for CheckIsRunning(CHECKISRUNNING_EDITORRENDERING) and CheckIsRunning(CHECKISRUNNING_EXTERNALRENDERING). And if either of those is TRUE, I use the full amount of clones. Of neither of them is TRUE, I include the Editor Weight. I currently can't recall if CHECKISRUNNING_EXTERNALRENDERING is set when rendering with Vray, but obviously it's not when rendering with Indigo.
Cheers,
Jack
Post by fused » Tue Oct 30, 2012 3:59 am
c4d-jack wrote:Nah, not my bug either ;-)
Cheers,
Jack
Hi Jack,
great to hear from you :)
The problem does not occur when rendering with Indigo, it only occurs when exporting the scene to disk (for rendering with the standalone version of Indigo).
In that case neither CheckIsRunning(CHECKISRUNNING_EDITORRENDERING) nor CheckIsRunning(CHECKISRUNNING_EXTERNALRENDERING) would return true.
I use the Hierarchy class to rebuild the scenes caches and pass BUILDFLAGS_EXTERNALRENDERER to it, normally a generator plugin should generate the render representation.
Not sure if bug is the right word, sorry if it sounded harsh. It's just that the behaviour is a bit unexpected (unconventional?) :)
If you want, we can discuss this privately, just email me: yves@indigorenderer.com
Cheers!
c4d-jack
Post by c4d-jack » Tue Oct 30, 2012 6:32 am
No problem! Bug is not harsh, as a developer I hear that word all the time :D
I`ll take a look at the buildflags. Since a customer recently discovered a bug in SurfaceSPREAD`s vertex map evaluation, I`ll have to release an update anyway. I just can`t guarantee when that will be.
Post by zeitmeister » Tue Oct 30, 2012 9:11 pm
Yeah Jack,
welcome to Indigo! :mrgreen: :mrgreen:
wlf_alex
Post by wlf_alex » Tue Oct 30, 2012 10:33 pm
Hola Jack !
Thanks for replay. I hope this small "bug" will be fixed any way. SurfaceSpread is very useful plug in and it will work with Indigo very well.
For example, SurfaceSpread in mine archiviz scene :
Post by fused » Fri Nov 02, 2012 4:21 am
wlf_alex wrote:Hola Jack !
Nice render :!:
Users browsing this forum: No registered users and 84 guests
