Well, uhmm, but how?StompinTom wrote:It's a volume renderingdakiru wrote:The scarf is extremely nice! Interesting to know how it was made, what do you think, guys?Simulation of the detailed mesh, maybe? The image is in the volume rendering section, so I have no idea..
No mesh.
Mitsuba renderer
Re: Mitsuba renderer
"The underlying volumes can be represented as sparse voxel octrees or as hierarchical grids, where grid cells are directly mapped from files into memory."dakiru wrote:Well, uhmm, but how?StompinTom wrote:It's a volume renderingdakiru wrote:The scarf is extremely nice! Interesting to know how it was made, what do you think, guys?Simulation of the detailed mesh, maybe? The image is in the volume rendering section, so I have no idea..
No mesh.
It was a one-man-project, mainly for researching algorithms, as stated.
IIRC it was used for the master thesis and PhD-research of Wenzel Jakob (the developer).
But he's still working on it, now under a open source licence.
And he is closely working together with some Blender Devs to get a very good COLLADA support between Blender and Mitsuba, which of course means good interaction with every other app that can properly export COLLADA-files (unlike Blender now
To sum it up: One-Man Project, only based on the newest cutting-edge algorithms and open source = awesome, imho.
Your ad here!
My brain hates Norton.snorky wrote:My Norton hates Mitsuba...
mtssrv.exe
http://securityresponse.symantec.com/se ... 00-2232-99
who use Norton
?! I remember one time when I made scan my hdd. All files from .max was deleted :p
Snorky!hcpiter wrote:who use Norton
my head office loves norton...hcpiter wrote:hehe lolfused wrote:Snorky!hcpiter wrote:who use Norton
The spirit of Radium renderer lives on
Ah no MLT in this release
Mitsuba 0.4 gets two types of MLT among lots of goodies, seems pretty fast too
Especially the Veach method. The other simplified one is like Indigo's, which piggy backs Path or Bidirectional path tracing.
Tried the Veach MLT method on the Sponza scene and it will hit 1024 samples in 6+ minutes on my i7 3930k at 4.2ghz system!
http://www.mitsuba-renderer.org/devblog ... nt+Blog%29
Veach MLT method from the manual
Like pssmlt, this integrator explores the space of light paths, searching with preference for those
that carry a significant amount of energy from an emitter to the sensor. The main difference is that
PSSMLT does this exploration by piggybacking on another rendering technique and “manipulating”
the random number stream that drives it, whereas MLT does not use such an indirection: it operates
directly on the actual light paths.
This means that the algorithm has access to considerably more information about the problem
to be solved, which allows it to perform a directed exploration of certain classes of light paths. The
main downside is that the implementation is rather complex, which may make it more susceptible
to unforeseen problems. Mitsuba reproduces the full MLT algorithm except for the lens subpath
mutation15. In addition, the plugin also provides the manifold perturbation proposed by Jakob and
Marschner
Path Space Metropolis Light Transport (MLT) is a seminal rendering technique proposed by Veach and Guibas, which applies the Metropolis-Hastings algorithm to the path-space formulation of light transport.
In contrast to simple methods like path tracing that render images by performing a naïve and memoryless random search for light paths, MLT actively searches for relevant light paths. Once such a path is found, the algorithm tries to explore neighboring paths to amortize the cost of the search. This is done with a clever set of path perturbations which can efficiently explore certain classes of paths. This method can often significantly improve the convergence rate of renderings that involve what one might call “difficult” input.
To my knowledge, this is the first publicly available implementation of this algorithm that works correctly.
Primary Sample Space Metropolis Light Transport (PSSMLT) by Kelemen et al. is a simplified version of the above algorithm.
Like MLT, this method relies on Markov Chain Monte Carlo integration, and it systematically explores the space of light paths, searching with preference for those that carry a significant amount of energy from an emitter to the sensor. The main difference is that PSSMLT does this exploration by piggybacking on another rendering technique and “manipulating” the random number stream that drives it. The Mitsuba version can operate either on top a unidirectional path tracer or a fully-fledged bidirectional path tracer with multiple importance sampling. This is a nice method to use when a scene is a little bit too difficult for a bidirectional path tracer to handle, in which case the extra adaptiveness due PSSMLT can bring it back into the realm of things that can be rendered within a reasonable amount of time.
This is the algorithm that’s widely implemented in commercial rendering packages that mention “Metropolis Light Transport” somewhere in their product description.
Energy redistribution path tracing by Cline et al. combines aspects of Path Tracing with the exploration strategies of Veach and Guibas. This method generates a large number of paths using a standard path tracing method, which are then used to seed a MLT-style renderer. It works hand in and with the next method:
Manifold Exploration by Jakob and Marschner is based on the idea that sets of paths contributing to the image naturally form manifolds in path space, which can be explored locally by a simple equation-solving iteration. This leads to a method that can render scenes involving complex specular and near-specular paths, which have traditionally been a source of difficulty in unbiased methods. The following renderings images (scene courtesy of Olesya Isaenko) were created with this method:
12 minute renders with the Veach MLT, on my i7 3930k at 4.2ghz system
Very impressive!
That Torus scene is like a pool/caustics scene, very difficult in the standard MLT in Indigo/Luxrender etc
Very impressive!
Veach MLT - direct light sampling off, about 15 mins or so render time
Manifold Perturbation option on vs off
Turning it on slows down the sample rate, but improves the convergence of the torus and refracted caustics - handy for pool scenes!
I also found it better to set number of bounces to -1, infinite, works better, more detail, and is more unbiased
from the PDF manual
from the PDF manual
To explore the space of light paths, MLT iteratively makes changes to a light path, which can either
belarge-scalemutationsorsmall-scaleperturbations. Roughlyspeaking,thebidirectionalmutationis
usedtojumpbetweendifferentclassesoflightpaths, andeachoneoftheperturbationsisresponsible
for efficiently exploring some of these classes. All mutation and perturbation strategies can be mixed
and matched as desired, though for the algorithm to work properly, the bidirectional mutation must
be active and perturbations should be selected as required based on the types of light paths that are
present in the input scene. The following perturbations are available:
(a) Lensperturbation: thisperturbationslightlyvariestheoutgoingdirectionatthecameraandprop-
agates the resulting ray until it encounters the first non-specular object. The perturbation then
attempts to create a connection to the (unchanged) remainder of the path.
(b) Caustic perturbation: essentially a lens perturbation that proceeds in the opposite direction.
(c) Multi-chain perturbation: used when there are several chains of specular interactions, as seen
in the swimming pool example above. After an initial lens perturbation, a cascade of additional
perturbationsisrequireduntilaconnectiontotheremainderofthepathcanfinallybeestablished.
Depending on the path type, the entire path may be changed by this.
(d) Manifold perturbation: thisperturbationwasdesignedtosubsumeandextendthepreviousthree
approaches. Itcreates a perturbation at anarbitrary position along thepath, proceedingin either
direction. Uponencounteringachainofspecularinteractions,itnumericallysolvesforaconnec-
tion path (as opposed to the cascading mechanism employed by the multi-chain perturbation).
Veach MLT - 10min render - only source of light is indirect lighting through windows and geometry seams
No exit portals or anything here
Wanted to see how many samples to reach a clean shadows with Veach MLT
8192 samples here - 30 min render
Hi cool!
Mitsuba seems to be a very cool rendering engine, even more after this very interesting last release!
..sadly there is no direct support for exporters, I suppose, so there's no way it is usable to us poor fiddlers..
I'm following with interest btw!
Users browsing this forum: DotBot [Bot] and 8 guests
