Carpaint ? Looks like aluminium vinyl foil or silk
- pixie
neat isn't it, but it's just the carpaint material, but instead of phong it uses diffuse and oren nayar for each of its blends.dcm wrote:Carpaint ? Looks like aluminium vinyl foil or silk
Im very big car enthusiast but this isnt carpaint
it looks like vinyl foil , like this frozen grey
http://www.bmwblog.com/wp-content/uploads/frozen1.jpg
- pixie
I never said it was, I said it was 'kind of a', because I downloaded the material, and the only thing I've changed was the material type from phong to diffuse/oren nayar. Pretty much about it, the original material is that of the link.dcm wrote:Im very big car enthusiast but this isnt carpaint
it looks like vinyl foil , like this frozen grey![]()
- LithiumDesign
It's still rendering, 2 hours in at 1900 samples!
my advice as before on dA: don't use MLT unless you have to!
- LithiumDesign
lycium wrote:my advice as before on dA: don't use MLT unless you have to!
BiDirPT
hmmm, it looks like MLT noise in the image
it's a diffuse transmitter on the right side? that might explain the extra noise (compared to directly visible lights).
should be PT but with high SS
- LithiumDesign
Yeah I knowlycium wrote:hmmm, it looks like MLT noise in the imageit's a diffuse transmitter on the right side? that might explain the extra noise (compared to directly visible lights).
I tried PT on it's own but couldn't get rid of the fireflies!!
EDIT: Ohhh super samples? It's currently on 4 with BiDirPT
yes, supersamples...i knew its 4 or 5
- LithiumDesign
So would PT and ss =6 be any good?dcm wrote:yes, supersamples...i knew its 4 or 5
you'll want to use bidir because of the diffuse transmitter.
- LithiumDesign
Left it running over night on PT with ss 6, 10 hours down and 10k samples;
No photoshop>
Photoshop>
No photoshop>
Photoshop>
