no images to show here, yet...
Parametric surfaces + shells
Re: Parametric surfaces + shells
You're gonna need more polygons in this scene, I still see terminator artifacts
will do, tmrw
Thumb up! Great seeing first unbiased to implement native paametrics. NURBS to come?
That looks really nice Ono, feed us with more!
Normal smoothing doesn't seem to kick in here
Now please melt those all together with some metaball algo
Scattered pebbles and shells.
50K pebbles and 100 shells.
Pebble and shell geometry are done with parametric surfaces.
NURBS will be implemented some dayrgigante wrote:Thumb up! Great seeing first unbiased to implement native paametrics. NURBS to come?
Niiice !
I don't know if that's possible already but it would be useful to use a displaced mesh as scattering surface, ie displace a terrain then scatter peebles over. Adding details to the detail.
An alternative would be to be able to modify the peebles position by a shader (displacement for instance). The scattering would be generated before subdivisions but matching them.
Ground just needs a bump texture (FBM?) and it would be perfectOnoSendai wrote:Sunset beach with narrower DOF.
The scattered pebbles are already scattered over the parametric surface, which is already displaced. So the scattering does follow the detailed surface.CTZn wrote:Niiice !
Well, this one already has 1M small pebblesStompinTom wrote:Ground just needs a bump texture (FBM?) and it would be perfectOnoSendai wrote:Sunset beach with narrower DOF.Can you render one with 5M pebbles? Like, covering the ground completely?
Dare you to put 10MOnoSendai wrote:Well, this one already has 1M small pebblesStompinTom wrote:Ground just needs a bump texture (FBM?) and it would be perfectOnoSendai wrote:Sunset beach with narrower DOF.Can you render one with 5M pebbles? Like, covering the ground completely?
