Blendigo for Blender 2.5 BETA
Locked
dougal2
Re: Blendigo for Blender 2.5 BETA
Post by dougal2 » Fri Aug 20, 2010 10:17 am
Borgleader wrote:Any updates since last month? I just tried ef_19f82ca.zip + indigo_BETA02 with Blender 2.53 beta and when i switch over to Indigo as a render engine all im getting are empty panels.
Things are still changing pretty fast with Blender at the minute, and there is very little that is new in the exporter since BETA02.
If you really want an updated version for the latest blender, I can try to do it this weekend.
Post by Borgleader » Fri Aug 20, 2010 10:21 am
I'm just wondering why my panels are empty :? Maybe I screwed up the installation?
Console output when I switch render engine to Indigo
dougal2
Post by dougal2 » Fri Aug 20, 2010 10:28 am
Certainly the blender version you have is too new for the BETA02 exporter.
I think there might be another issue too - perhaps broken release or installation ?
dakiru
Post by dakiru » Fri Aug 20, 2010 10:31 am
dougal2 wrote:Certainly the blender version you have is too new for the BETA02 exporter.
I tried it before (with blender 2.53) and it's the same as Borgleader's experience - nothing on the panels.
Post by Borgleader » Fri Aug 20, 2010 11:04 am
It seems the first chunk of errors (everything before the "indigo initialized" line) can be "fixed" by deleting the netrender folder. The rest seems to have to do with stuff being call with 'no_bg' as an argument which is invalid somehow.
EDIT:
Open ef/ui.py (in a text editor)
Replace all "no_bg" with "emboss" and the errors will go away :)
It still wont render because apparently "Output path is not writable" but...the menus show up :?
fixed panel
Post by Borgleader » Fri Aug 20, 2010 11:32 am
I grabbed the latest version of the ef folder from your website...
What is : t(**a) ? I commented it and the errors went away but with this version of the ef folder, indigo doesnt appear in the render engine menu.
Ok so I opened all of the ef files from the ef19f82ca & the version i found on your website and i looked at the differences between the two.
Oddly I dont remember t(**a) giving errors with ef19f82ca but it does with the other version. And by adding two blocks of code from the plugin.py (or engine.py i cant remember) i was able to get indigo to appear in the render engine menu. But the actual panels wouldnt show up -.-;
i hope im not confusing you
dougal2
Post by dougal2 » Fri Aug 20, 2010 11:52 am
Borgleader wrote:I grabbed the latest version of the ef folder from your website...
Ok, I take the hint, i'l post up a new beta this weekend :)
Post by Borgleader » Fri Aug 20, 2010 11:55 am
I want to help! :(
dougal2
Post by dougal2 » Fri Aug 20, 2010 10:04 pm
Borgleader wrote:I want to help! :(
OK, the current code is in two parts.
Looks like you already found the EF library: http://github.com/doughammond/exporterframework
Use the 'download source' button on the github page to get a .zip of the current code.
Copy the ef/ folder from that repository into your scripts/io/ folder.
Then you need the Blendigo code: http://github.com/doughammond/blendigo-2.5
Copy the sources/indigo folder into your scripts/io/ folder.
The code that is currently on github requires a version of blender that is newer than the official 2.53 beta release. You can grab very new builds from http://graphicall.org/
Post by Borgleader » Sat Aug 21, 2010 5:02 am
Ok so I grabbed both:
doughammond-blendigo-2.5-f56d2ca.zip
doughammond-exporterframework-a61891e.zip
and I'm running Blender 2.5 rev31168
from properties_data_camera import CameraButtonsPanel
This line seems to be causing problems:
"Cannot import name CameraButtonsPanel" in file indigo/panels/camera.py
also I dont see indigo in the list of engines but i figure its probably because of the error (since I dont see an "indigo initialised" message either)
dougal2
Post by dougal2 » Sat Aug 21, 2010 5:18 am
Borgleader wrote:... and I'm running Blender 2.5 rev31168 ...
That's too old :(
Something closer to r314XX would be better.
Post by Borgleader » Sat Aug 21, 2010 5:28 am
That's too old :(
w00tles!
Again, nuked the netrender folder and now the menus are working! :) Tyvm dougal2, I'll report when i break it :twisted: :lol:
Post by Borgleader » Sat Aug 21, 2010 6:06 am
Output path still not writable :(
dougal2
Post by dougal2 » Sat Aug 21, 2010 6:13 am
Borgleader wrote:Output path still not writable :(
And what have you set the output path to ?
Post by Borgleader » Sat Aug 21, 2010 6:16 am
Same directory as the .blend file (in the text box i think it shows up as // but before it was set to /tmp\ and it wasnt working either)
Locked
