Indigo 0.7F exporter here! Features added/Comments welcome!
Wedge
Post by Wedge » Thu Mar 15, 2007 6:38 pm
Maybe fresnel will help? Have you already tried lowering the exponent of the material?
F.ip2
Post by F.ip2 » Thu Mar 15, 2007 6:49 pm
yes it is around 40 already. in case i lower it more the specular reflection will overlap my brush map.
how do you setup SSS and so with your exporter??? i used blendigo sofar.
Artist : Designer : Educator
of Ferris State University
Wedge
Post by Wedge » Thu Mar 15, 2007 6:57 pm
How about adding an object to the scene, a cube or plane (or even a sphere), right above the faucet so the camera does not catch it. Place it between the top of the faucet area and the the light causing the problem.
Size it and see how it shows up in the faucet reflection.
Bad idea?
F.ip2
Post by F.ip2 » Thu Mar 15, 2007 7:20 pm
lol, let me try it ;)
F.ip2
Post by F.ip2 » Thu Mar 15, 2007 7:24 pm
you are a genius - did not think about that ;) works perfectly!!!
carbon
Post by carbon » Sat Mar 17, 2007 8:01 am
PLEASE HELP ME!!!
i am still getting this:
Compiled with Python version 2.3.
Checking for installed Python... got it!
INDIGO EXPORT
Saving to '/export/mat.xml'...
processing Camera
processing subsurface_backshield (Mesh Plane.009)
processing subsurface_backlight as Meshlight (Mesh Plane.004)
processing sub_bar1.001 (Mesh Cube.005)
processing sub_bar1 (Mesh Cube.001)
processing emit_top_shield (Mesh Plane.010)
processing emit_top as Meshlight (Mesh Plane.005)
processing light_diff_shield (Mesh Plane.007)
processing MAT_sphere (Mesh Cube.002)
processing MAT_circle (Mesh Circle.002)
processing stand_circle (Mesh Circle.001)
processing box_front (Mesh Cube.014)
processing box_left (Mesh Cube.013)
processing box_top (Mesh Cube.012)
processing box_right (Mesh Cube.011)
processing box_back (Mesh Cube.010)
processing box_bottom (Mesh Cube.009)
processing stand_sphere (Mesh Circle)
processing light_diff as Meshlight (Mesh Plane)
Skip Camera (type Camera)
DONE
Processing time: 5.99
and inside xml there is no camera tag.. i'm using Blender 2.43 and i am getting the same result with all exporter versions i have collected..
carbon
Post by carbon » Sat Mar 17, 2007 8:06 am
PLEASE HELP ME!!!
INDIGO EXPORT
processing Camera
DONE
F.ip2
Post by F.ip2 » Sat Mar 17, 2007 11:10 am
could you publish striped down blend file?
carbon
Post by carbon » Sat Mar 17, 2007 11:12 am
it makes every blend file ive tried.. even default scene
carbon
Post by carbon » Sat Mar 17, 2007 11:25 am
this:
import Blender
from Blender import Scene
currentscene = Scene.GetCurrent()
camObj = currentscene.getCurrentCamera()
print camObj
returns: None
i dont know if there isnt any mistake, im no python coder, got only really basic knowledge of py
Wedge
Post by Wedge » Sat Mar 17, 2007 3:27 pm
Fip: Defining materials in this exporter is confusing. The directions are at the front page. Good to hear your faucet is looking good.
Carbon: I do not know why this does not work. Maybe it has something to do with Python 2.3? Can you use the latest 2.4 Python version?
carbon
Post by carbon » Sat Mar 17, 2007 9:10 pm
i don't think that this is the problem, the same script used to work couple days ago :cry:
tobak30
Error message
Post by tobak30 » Sun Mar 18, 2007 1:54 pm
I wonder what this mean. I don't know what it is and what is wrong. I looked into the xml file and it said:
<model>
<pos>7.6413 -9.5215 3.1765</pos>
<scale>0.0452</scale>
<rotation>
<matrix>
0.763570 0.000000 0.000000 0.000000 0.763570 0.000000 0.000000 0.000000 1.472860
</matrix>
</rotation>
<mesh_name>Cylinder</mesh_name>
</model>
Edit: I have found out wich object it is that causes the trouble. But how it creates the problem I don't understand.
joegiampaoli
Post by joegiampaoli » Sun Mar 18, 2007 2:14 pm
Select all your objects in blender and hit Ctrl+A then export....might need to re-tweak some scalings.
Joe Giampaoli
My Indigo Gallery
tobak30
Post by tobak30 » Sun Mar 18, 2007 2:33 pm
Thank you so much for your help. it works now. There is so much I don't know and I am still learning.
Users browsing this forum: Google [Bot] and 52 guests
