Indigo 0.7F exporter here! Features added/Comments welcome!
yes it is around 40 already. in case i lower it more the specular reflection will overlap my brush map.
how do you setup SSS and so with your exporter??? i used blendigo sofar.
Artist : Designer : Educator
of Ferris State University
How about adding an object to the scene, a cube or plane (or even a sphere), right above the faucet so the camera does not catch it. Place it between the top of the faucet area and the the light causing the problem.
Size it and see how it shows up in the faucet reflection.
Bad idea?
Bad idea?
PLEASE HELP ME!!!
i am still getting this:
Compiled with Python version 2.3.
Checking for installed Python... got it!
INDIGO EXPORT
Saving to '/export/mat.xml'...
processing Camera
processing subsurface_backshield (Mesh Plane.009)
processing subsurface_backlight as Meshlight (Mesh Plane.004)
processing sub_bar1.001 (Mesh Cube.005)
processing sub_bar1 (Mesh Cube.001)
processing emit_top_shield (Mesh Plane.010)
processing emit_top as Meshlight (Mesh Plane.005)
processing light_diff_shield (Mesh Plane.007)
processing MAT_sphere (Mesh Cube.002)
processing MAT_circle (Mesh Circle.002)
processing stand_circle (Mesh Circle.001)
processing box_front (Mesh Cube.014)
processing box_left (Mesh Cube.013)
processing box_top (Mesh Cube.012)
processing box_right (Mesh Cube.011)
processing box_back (Mesh Cube.010)
processing box_bottom (Mesh Cube.009)
processing stand_sphere (Mesh Circle)
processing light_diff as Meshlight (Mesh Plane)
Skip Camera (type Camera)
DONE
Processing time: 5.99
and inside xml there is no camera tag.. i'm using Blender 2.43 and i am getting the same result with all exporter versions i have collected..
INDIGO EXPORT
processing Camera
DONE
PLEASE HELP ME!!!
INDIGO EXPORT
processing Camera
DONE
INDIGO EXPORT
processing Camera
DONE
Fip: Defining materials in this exporter is confusing. The directions are at the front page. Good to hear your faucet is looking good.
Carbon: I do not know why this does not work. Maybe it has something to do with Python 2.3? Can you use the latest 2.4 Python version?
tobak30
Error message
I wonder what this mean. I don't know what it is and what is wrong. I looked into the xml file and it said:
<model>
<pos>7.6413 -9.5215 3.1765</pos>
<scale>0.0452</scale>
<rotation>
<matrix>
0.763570 0.000000 0.000000 0.000000 0.763570 0.000000 0.000000 0.000000 1.472860
</matrix>
</rotation>
<mesh_name>Cylinder</mesh_name>
</model>
Edit: I have found out wich object it is that causes the trouble. But how it creates the problem I don't understand.
<model>
<rotation>
<matrix>
</matrix>
</rotation>
</model>
- error2.jpg (52.23 KiB) Viewed 4600 times
- joegiampaoli
