Caustics...How to?
15 posts • Page 1 of 1
mario
Caustics...How to?
Post by mario » Tue Feb 27, 2007 4:46 am
I have a little problem: with a thin lens model, ( material glass with IOR 1.2) i can't view caustics....Why???
I have see a beautiful cardioid caustic in Artwork gallery, but i dont have nor a little caustic....
What's the best parameters fo a lens glass?
Suggestions?
Thanks
Mario
Ho un piccolo problema: per quanto provi, non riesco ad ottenere caustiche, con un modello di lende in vetro (IOR 1.2) non vengono fuori... Perchè?
Qualche suggerimento?
Grazie
Mario
Post by Kram1032 » Tue Feb 27, 2007 7:10 am
1) Please show an example
2) Please post a part of the scene
3) Which V of Indigo do you use
4) ... Ok, I think, that's it..
Maybe, no light is falling on / trough the lens, or all the other light is too bright, to see any caustics...
mario
Caustics
Post by mario » Wed Feb 28, 2007 5:46 am
Oh, the problem is with 0.6, 0.7t5, 0.7t1!!!
I can't post the image because i'm not able to post it, but in the scene there is only a little lens , a plane and a sun light...
Material is transparent, with IOR of 1.2. Suggestion for material?
Excuse me, but i'll try to post the image..
Thanks
Post by Kram1032 » Wed Feb 28, 2007 8:02 am
use either http://www.imageshack.us
or
http://photobucket.com
most are using first one, I'm using second one ;)
Post by CTZn » Wed Feb 28, 2007 8:54 am
Most are wrong :twisted:
Post by Kram1032 » Wed Feb 28, 2007 9:29 am
I thk so, too!
That's why I'm using photobucket :P
mario
Caustics
Post by mario » Thu Mar 01, 2007 3:20 am
OK, the image is here
http://img375.imageshack.us/my.php?imag ... 199ln2.png
and this is with 0.6, bidirectional on
In Blendigo, when i try to export the file, whwn bidirectional is on, he say " Fatal error : bidirectional disabled"!!!
Why?
Thanks
Post by Kram1032 » Thu Mar 01, 2007 3:34 am
Very simple:
Blendigo is written for 0.7.x, where BidDir is disabled, 'cause of a bug.
Indigo would crash with BiDir on...
Don't use Blendigo for 0.6.x, where BiDir works: It wont work propperly with any transparent mat!
Here, in this pic, I can see caustics :D
mario
Post by mario » Fri Mar 02, 2007 8:09 am
OK, this is with 0.6 and BiDir on!!
So, in 0.7 is impossible to obtain caustics???? Is correct this trouble?
In 0.6 or 0.5 or another without BiDir i can't see caustics!!!
javascript:emoticon(':roll:')
Rolling Eyes
Suggestions???
Thanks!!!
Mario
Post by CTZn » Fri Mar 02, 2007 9:21 am
I'm not sure but I think there are caustics in your scene, since every light passed through a medium or glass is a caustic light. Maybe we would need to see a closer and different point of view. But the caustics of your sphere are strange, looks like every face is separated from its neighbouring, must be a geometry issue.
Post by Kram1032 » Sat Mar 03, 2007 8:40 am
CTZn wrote:I'm not sure but I think there are caustics in your scene, since every light passed through a medium or glass is a caustic light. Maybe we would need to see a closer and different point of view. But the caustics of your sphere are strange, looks like every face is separated from its neighbouring, must be a geometry issue.
Kram1032 wrote:Here, in this pic, I can see caustics :D
Caustics
Maybe, you don't know, what caustics are... Check out the link ;)
It's light, that either is bundled through a transparent material or by a mirrormaterial.
This description may not be completely correct, but it should be near to the phnomena ;)
Indigo 0.7 IS able to produce caustics, but for some reason, there is a Bug with BiDir... So, atm, it's deactivated...
An other thing is, that Blendigo exports 0.7-Mats, which are completely entirely different to 0.6-Mats. That's, why you shouldn't use it for 0.6!
mario
Post by mario » Sat Mar 03, 2007 9:52 pm
Ok, in the image i can see two caustics: one from the sfere, other from the lens.
In 0.6 all is Ok, but in 0.7 I don't understand if is possible to obtain caustics, without BiDir: exist a method? Is the wrong setup of the material? Have you a setup for 0.7's caustics?
The second question: I love 0.6, but with Blendigo i can obtain easily bump mup and others, but 0.6 works very well for others works!!!
Suggestions?
Thanks
Mario
Post by Kram1032 » Sat Mar 03, 2007 9:57 pm
Caustics are possible in 0.7 just like in 0.6!
BiDir (I think) just makes them appear faster but slows down the general render-speedity...
But I want to have it back anyway!!!
:D
mario
Post by mario » Sun Mar 04, 2007 2:14 am
Thanks, i'll try and, when my work is OK i'll post it.
Thanks
Mario
Post by Kram1032 » Sun Mar 04, 2007 2:24 am
np ;)
