Caustics...How to?
Caustics...How to?
I have a little problem: with a thin lens model, ( material glass with IOR 1.2) i can't view caustics....Why???
I have see a beautiful cardioid caustic in Artwork gallery, but i dont have nor a little caustic....
What's the best parameters fo a lens glass?
Suggestions?
Thanks
Mario
Ho un piccolo problema: per quanto provi, non riesco ad ottenere caustiche, con un modello di lende in vetro (IOR 1.2) non vengono fuori... Perchè?
Qualche suggerimento?
Grazie
Mario
Suggestions?
Thanks
Mario
Grazie
Mario
Caustics
Oh, the problem is with 0.6, 0.7t5, 0.7t1!!!
I can't post the image because i'm not able to post it, but in the scene there is only a little lens , a plane and a sun light...
Material is transparent, with IOR of 1.2. Suggestion for material?
Excuse me, but i'll try to post the image..
Thanks
Thanks
use either http://www.imageshack.us
or
http://photobucket.com
most are using first one, I'm using second one
or
Caustics
OK, the image is here
http://img375.imageshack.us/my.php?imag ... 199ln2.png
and this is with 0.6, bidirectional on
In Blendigo, when i try to export the file, whwn bidirectional is on, he say " Fatal error : bidirectional disabled"!!!
Why?
Thanks
Why?
Thanks
I'm not sure but I think there are caustics in your scene, since every light passed through a medium or glass is a caustic light. Maybe we would need to see a closer and different point of view. But the caustics of your sphere are strange, looks like every face is separated from its neighbouring, must be a geometry issue.
CTZn wrote:I'm not sure but I think there are caustics in your scene, since every light passed through a medium or glass is a caustic light. Maybe we would need to see a closer and different point of view. But the caustics of your sphere are strange, looks like every face is separated from its neighbouring, must be a geometry issue.
CausticsKram1032 wrote:Here, in this pic, I can see caustics
Maybe, you don't know, what caustics are... Check out the link
It's light, that either is bundled through a transparent material or by a mirrormaterial.
This description may not be completely correct, but it should be near to the phnomena
Indigo 0.7 IS able to produce caustics, but for some reason, there is a Bug with BiDir... So, atm, it's deactivated...
An other thing is, that Blendigo exports 0.7-Mats, which are completely entirely different to 0.6-Mats. That's, why you shouldn't use it for 0.6!
Ok, in the image i can see two caustics: one from the sfere, other from the lens.
In 0.6 all is Ok, but in 0.7 I don't understand if is possible to obtain caustics, without BiDir: exist a method? Is the wrong setup of the material? Have you a setup for 0.7's caustics?
The second question: I love 0.6, but with Blendigo i can obtain easily bump mup and others, but 0.6 works very well for others works!!!
Suggestions?
Thanks
Mario
Suggestions?
Thanks
Mario
