problem
Come here for help & support.
horpa
problem
Post by horpa » Tue Dec 18, 2018 2:53 am
Hello,
indigo does not see my new graphics card - rtx2080. Why? Thx.
Re: problem
Post by pixie » Tue Dec 18, 2018 8:03 am
Try installing the latest graphic drivers, it works on my new RTX 2080
horpa
Re: problem
Post by horpa » Tue Dec 18, 2018 6:55 pm
I have installed
kscore
Re: problem
Post by kscore » Wed Dec 19, 2018 4:17 am
@horpa: Does it work now? Are u happy with the performance of the new rtx card?
horpa
Re: problem
Post by horpa » Wed Dec 19, 2018 7:57 am
Unfortunately, it does not work. I want to test the use for my work but it does not work for me.
Re: problem
Post by OnoSendai » Wed Dec 19, 2018 2:52 pm
What OS are you using?
horpa
Re: problem
Post by horpa » Wed Dec 19, 2018 7:18 pm
win 10 pro
horpa
Re: problem
Post by horpa » Thu Dec 20, 2018 7:15 am
some idea?
burnin
Re: problem
Post by burnin » Thu Dec 20, 2018 10:14 pm
if you haven't yet, uninstall automatic windows drivers > install NVidia ones (if latest don't work, try with previous versions)
horpa
Re: problem
Post by horpa » Fri Dec 21, 2018 5:13 am
I did it, but it does not work - I test thea render - no problem
Re: problem
Post by pixie » Fri Dec 21, 2018 9:19 am
I think thea doesn't use opencl, it should be due to it
burnin
Re: problem
Post by burnin » Fri Dec 21, 2018 12:23 pm
Well, i've been observing "latest NVidia drivers" occasional breaking OCL rendering for more than couple of years already, why i always have a backup drivers ready & i've recently noticed elsewhere that v.417 is again broken...
didn't test it as i don't have to :)
horpa
Re: problem
Post by horpa » Sat Dec 22, 2018 4:47 am
...hmmm ...I want to upgrade to indigo 4 - now I do not know...
Re: problem
Post by pixie » Sat Dec 22, 2018 5:48 am
It is working fine on my RTX, it doesn't help that NVIDIA is so picky with OpenCL though...
burnin
Re: problem
Post by burnin » Sat Dec 22, 2018 6:02 am
That's why demos are available & users are here sharing experience.
IMHO, it's nothing to worry about, just don't follow the hype blindly, but get experienced yourself.
I got a Maxwell (Q M5000) and a Pascal (GTX 1060) cards so it's a bit trickier to "update drivers" since they don't fully comply, but i learned my lesson through trial & error, so now i have it all running smoothly when using OCL (CPU + GPU).
Also pixie states his RTX 2080 is running fine.
Did you perform any other OCL (GPU/CPU) tests to see, if you have everything installed and working otherwise?
I use GPU Caps viewer, GPU-Z & CPU-Z
