problem
- pixie
Re: problem
Try installing the latest graphic drivers, it works on my new RTX 2080
Re: problem
@horpa: Does it work now? Are u happy with the performance of the new rtx card?
Re: problem
Unfortunately, it does not work. I want to test the use for my work but it does not work for me.
Re: problem
What OS are you using?
Re: problem
if you haven't yet, uninstall automatic windows drivers > install NVidia ones (if latest don't work, try with previous versions)
Re: problem
I did it, but it does not work - I test thea render - no problem
Re: problem
Well, i've been observing "latest NVidia drivers" occasional breaking OCL rendering for more than couple of years already, why i always have a backup drivers ready & i've recently noticed elsewhere that v.417 is again broken...
didn't test it as i don't have to
Re: problem
...hmmm ...I want to upgrade to indigo 4 - now I do not know...
- pixie
Re: problem
It is working fine on my RTX, it doesn't help that NVIDIA is so picky with OpenCL though...
Re: problem
That's why demos are available & users are here sharing experience.
IMHO, it's nothing to worry about, just don't follow the hype blindly, but get experienced yourself.
I got a Maxwell (Q M5000) and a Pascal (GTX 1060) cards so it's a bit trickier to "update drivers" since they don't fully comply, but i learned my lesson through trial & error, so now i have it all running smoothly when using OCL (CPU + GPU).
Also pixie states his RTX 2080 is running fine.
Did you perform any other OCL (GPU/CPU) tests to see, if you have everything installed and working otherwise?
I use GPU Caps viewer, GPU-Z & CPU-Z
Users browsing this forum: No registered users and 71 guests
