Can't have physical sky+sun and light materials.
tlehmann1996
Why wont indigo let me have sun coming through a window and have objects with light emitters at the same time?
Dell Studio 1737 on Vista64
Intel Core 2 Duo CPU T6400 @2.00GHz 2.00GHz
4GB RAM
4GB RAM
- Borgleader
Re: Can't have physical sky+sun and light materials.
What do you mean it doesnt let you? Because...it should. Can you be more specific about the error you're getting?tlehmann1996 wrote:Why wont indigo let me have sun coming through a window and have objects with light emitters at the same time?
tlehmann1996
The second picture I have it set to Physical Sky+Sun and has no lights. The first is what happened when I added four squashed spheres with light emitting materials, without changing any other settings outside of materials. When I hit render the environment option switches from physical sky+sun to background color, and when I switch it back and render it again, it changes to bg color again.
4GB RAM
4GB RAM
Can indigo have both ( sun and ligh materials) in one scene? How?
Skindigo
- pixie
You would have to set the inner lights strenghs way up so that they can have a real impact on the scene, and then use layers to tune them up.tarikb wrote:Can indigo have both ( sun and ligh materials) in one scene? How?
tlehmann1996
Turning up the light strength wont do anything though, will it? I need both sun and lights, and right now I'm getting just lights.
4GB RAM
4GB RAM
The eternal suffering... it isn't very easy.
Each light material needs to be aligned in illumination strength to fit with the other sources.
If you use Sun as lightsource (that has fixed illumination strength) you need to align your
meshlights! Simply Reduce the strength of the emitters...
tlehmann1996
No matter how much I change the power of the light material, nothing changes. They are either on or off. The only way I could do that was to turn gain completely off, then the lights went off and the sun came in. But when I turned gain up even to 0.0001, the lights are back to their usual power and the sun is gone...
4GB RAM
4GB RAM
Seems Reinhard tonemapping is the evil here
change to linear or camera tonemapping.
Light Sources also can be also restrained using the "Emission Scale" feature.
tlehmann1996
I tried setting it to both camera and linear, but still no sun. Any other ideas?
4GB RAM
4GB RAM
- PureSpider
Seems like you guys get him wrong...
Looks like an exporter issue.
As soon as he turns on the lights, the environment changes from sun to black background!
Nothing to do with Reinhard or whatever!
tlehmann1996
If it's an exporter issue, how can I fix it? I've had this problem on all of my interior models and have just dealt with it.
4GB RAM
4GB RAM
easiest way to get this solved is to reduce your scene to room + lights (no furniture) and post the scene here, so we can have a look.
Its very uncommon that new users just find critical bugs... its more often a wrong understanding of the exporter
tlehmann1996
Do you need a render or settings? If so, what settings do you need?
4GB RAM
4GB RAM
- Borgleader
All of them just make a copy of your scene file (c4d/max/blend/...) in the copy take out all the furniture, leave only the walls /lights ... like zomb said, compress it to .zip and post it.tlehmann1996 wrote:Do you need a render or settings? If so, what settings do you need?
Users browsing this forum: No registered users and 86 guests
