Carpet and fabrics!
15 posts • Page 1 of 1
benn
Carpet and fabrics!
Post by benn » Fri Oct 02, 2009 10:15 am
Can we have a cream coloured carpet and a nice fabric covering for sketchup furnitures? :D
Camox
Re: Carpet and fabrics!
Post by Camox » Fri Oct 23, 2009 4:09 am
Hi Ben, if you like the materials I'll upload them.
best regards :wink:
Doug Armand
Post by Doug Armand » Fri Oct 23, 2009 4:26 am
Camox wrote:Hi Ben, if you like the materials I'll upload them.
best regards :wink:
Well for me they are just too perfect. :wink:
I mean who will believe we've rendered an image if we use materials as good as this?
How do we convince the client to pay then? they'll just say we used a camera for goodness sake!
But seriously :D - that is a very, very good material. I can't see the seams. Would be nice to a hi-res render
Great work
Doug
Doug Armand
Camox
Post by Camox » Fri Oct 23, 2009 4:32 am
:oops: Thank you very much Doug ! :D
If I have a little more time, then I will render an image in hi-res. This comes in the next few days.
greetz :wink:
benn
Post by benn » Fri Oct 23, 2009 8:23 am
:o
Those materials are awesome. Please do upload. :)
Camox
Post by Camox » Fri Oct 23, 2009 9:12 am
Thanks :D
I've uploaded the materials. :wink:
Godzilla
Post by Godzilla » Fri Oct 23, 2009 9:21 am
Camox wrote:Thanks :D
Woah woah woah, you gotta do a material preview, friend. :lol:
Camox
Post by Camox » Fri Oct 23, 2009 9:26 am
Yes my friend, i think i have too many time. :wink:
Jambert
Post by Jambert » Fri Oct 23, 2009 7:26 pm
thanks fot upload :)
ozzie
Post by ozzie » Wed Nov 11, 2009 11:19 am
And how can I make carpet like that:
I know I can use displacement texture but every time I'm trying it's not what it should be! Any ideas?
Some examples of what I've got on my mind:
http://www.vray-materials.de/all_materials.php?mat=1409
http://www.vray-materials.de/all_materials.php?mat=1628
http://www.vray-materials.de/all_materials.php?mat=1482
Post by lycium » Wed Nov 11, 2009 11:23 am
a (somewhat slow) way: you could use several layers of textures, blending between diffuse and null material. memory usage will be a lot lower than displacement.
actually, if you do this, i would be interested to see 64bit vs 32bit benchmarks, since the 64bit version (on windows) doesn't actually do shader compiling as far as i know.
Post by CTZn » Wed Nov 11, 2009 6:02 pm
Ozzie, you could also use the same technique than for grass, by instancing billboards such as this one (with seamless sides):
Imagealbedo
Imagebump
Imageblend
ozzie
Post by ozzie » Wed Nov 11, 2009 11:19 pm
lyc - I think it will give the best reuslts, but for now I don't have any ideas how to do it :/.
CTZn - it's bad idea because I don't know the what perspective will be - but it will be much faster to do than what lyc sad
Post by Zom-B » Thu Nov 12, 2009 12:16 am
I just tried the Billboard version here.10000 copies, zoomed in to fit in the screen, HDR light.
The billboards are randomly rotated and have a random angle of 25°.
I needed to convert Bump + blend to RGB and flip BW for the Blend.
550 SPP, smooth blend & Bump Map
Render times are very high since the multiple transparency and the small size are quite a issue. A carper looks by default Noisy at some point.
I'll give it a trest with Step blend and no bump... this should speed up everything :)
Post by CTZn » Thu Nov 12, 2009 3:12 am
Thanks for testing ZomB, I'm finding the result not so bad after all. I think it should be decent in a real situation, hiding objects partially.
Now I see the limit of standing blades, but I can make a variety of these billboards in no time, along with a related tileable texture for the carpet surface.
The bump map is an extra... Step blend should definitly boost the process !
