And by current scene you mean - it saves the changes you've made in the GUI to an IGS?OnoSendai wrote:* Added 'Save Scene' command to File menu to allow saving current scene as an IGS or PIGS.
Indigo 2.2.8
- PureSpider
Re: Indigo 2.2.8
Re: Indigo 2.2.8
Awesome, thanks!
Re: Indigo 2.2.8
No, it doesn't actually save those settings currently, I'll add that.PureSpider wrote:And by current scene you mean - it saves the changes you've made in the GUI to an IGS?OnoSendai wrote:* Added 'Save Scene' command to File menu to allow saving current scene as an IGS or PIGS.
Re: Indigo 2.2.8
Thank you very much!
Some things I noticed...
I really like that the Options dialog remembers its previous state.
Sadly, however, it doesn't read the tags (from the ini or igs) if they are present.
(I tried these: info_overlay, watermark, frame_upload_period and save_igi)
When rendering is paused, the render log continues to update
(with no changes) and the image continues to tonemap & save.
However, this takes almost no cpu.
feature requests:
A new section in the inifile.xml file:
<ui_settings>
<thread_priority>normal</thread_priority> <!-- normal or below_normal -->
<confirm_quit_render_on_exit>yes<confirm_quit_render_on_exit> <!-- yes or no -->
</ui_settings>
Hopefully there is a more concise way to say "confirm_quit_render_on_exit",
but something that would let you stop rendering & close indigo in one click.
Naturally, these would default to current behavior.
Finally, it seems that when using an obj file as an external mesh,
the fo keyword (one-sided face) is not supported. Perhaps this was
by design, but if not, any chance of interpreting 'fo' a standard
two-sided face?
But its just details... keep doing what you're doing!
feature requests:
<ui_settings>
</ui_settings>
two-sided face?
- pixie
Re: Indigo 2.2.8
+1Musorgki wrote:feature requests:
<ui_settings>
</ui_settings>
Re: Indigo 2.2.8
I tested it in an older scene: launched 2552x1708 with three light layers and...no damn C++ messages!!!!!OnoSendai wrote: Changelog:
2.2.8:
* Optimised tonemapping, using less buffers, and made multithreaded.
I'm quite happy with this, congratulations for your work.
I'm very happy for the additional on-the-run "save igi" option too: it is VEEEERY useful!
Thank you a lot!
Re: Indigo 2.2.8
Supersample multiply image size of network rendered image.
I render 1500/1500 pixels
Total render time elapsed: 19 m, 6 s
Done 1193030000.00000 samples (530.23556 samples per pixel)
1040247.83680 samples / second (0.96131 micro-seconds / sample)
Receiving frame from 192.168.0.2:49567 :
num layers: 1, num_samples: 16400000.000000, width: 3004, height: 3004
Re: Indigo 2.2.8
SuperSampling works by rendering the Image in higher resolution and the resizing it back.Jambert wrote:Supersample multiply image size of network rendered image.
Everything fine with this my friend :)
Re: Indigo 2.2.8
thx ;)ZomB wrote:SuperSampling works by rendering the Image in higher resolution and the resizing it back.Jambert wrote:Supersample multiply image size of network rendered image.
Re: Indigo 2.2.8
It looks like you have the default image save period set to 20 seconds. This is WAY too short. I suggest a minimum of 60 seconds (I prefer 120 or even longer)
Re: Indigo 2.2.8
I think the rendering options are nice but they should be overwritten by the IGS file.
Re: Indigo 2.2.8
[EDIT] ah, nevermind.. just saw the other thread about this..
hey ben,
before i install v2.2.8, do you mind giving a little more info about this '34' bit build?
- osx 34bit
- screen 2.jpg (21.9 KiB) Viewed 4569 times
- Doug Armand
Re: Indigo 2.2.8
Bah wrong thread - sorry :(
Re: Indigo 2.2.8
Hey Ono, the eroor message for missing texture on netrender etwork cache generation could be a little more comfortasble to understand...
At the moment Indigo Indigo only tells you that its unable to pack the scene.
Users browsing this forum: Google [Bot] and 6 guests
