Built-in functions – Maths utility functions
pi() real
Returns pi.
mod(real x, real y) real
mod(int x, int y) int
Returns the remainder of x / y.
sin(real x) real
Returns sin(x).
asin(real x) real
Returns sin^-1(x).
cos(real x) real
Returns cos(x).
acos(real x) real
Returns cos^-1(x).
tan(real x) real
Returns tan(x).
atan(real x) real
Returns tan^-1(x).
atan2(real y, real x) real
Returns tan^-1(y/x), mapped into the range [-pi, pi]
abs(real x) real
abs(int x) int
Returns the absolute value of x.
exp(real x) real
Returns e^x.
pow(real x, real y) real
Returns x^y.
sqrt(real x) real
Returns x^1/2.
log(real x) real
Returns the natural logarithm of x, ln(x).
floor(real x) real
Returns the largest integer y, such that x >= y.
ceil(real x) real
Returns the smallest integer y, such that x <= y.
fract(real x) real
Returns x – floor(x).
floorToInt(real x) int
Returns floor(x) converted to an integer.
ceilToInt(real x) int
Returns ceil(x) converted to an integer.
real(int x) real
Converts x to type real.
min(int x, int y) int
min(real x, real y) real
min(vec2 x, vec2 y) vec2
min(vec3 x, vec3 y) vec3
If x < y, returns x, otherwise returns y.
In the case of vec2 or vec3 arguments, the comparison is done component-wise.
max(int x, int y) int
max(real x, real y) real
max(vec2 x, vec2 y) vec2
max(vec3 x, vec3 y) vec3
If x > y, returns x, otherwise returns y.
In the case of vec2 or vec3 arguments, the comparision is done component-wise.
lerp(real x, real y, real t) real
lerp(vec2 x, vec2 y, real t) vec2
lerp(vec3 x, vec3 y, real t) vec3
Returns x * (1 – t) + y * t
clamp(int x, int minval, int maxval) int
clamp(real x, real minval, real maxval) real
clamp(vec2 x, vec2 minval, vec2 maxval) vec2.
clamp(vec3 x, vec3 minval, vec3 maxval) vec3
Returns max(minval, min(maxval, x)).
In the case of vec2 or vec3 arguments, the clamping is done component-wise.
Undefined if minval > maxval.
step(real step_x, real x) real
Returns 1 if x >= step_x, 0 otherwise.
smoothstep(real a, real b, real x) real
Returns 0 if x <= a, 1 if x >= b, and interpolates smoothly between 0 and 1 as x ranges from a to b.
smootherstep(real a, real b, real x) real
Like smoothstep but smoother.
pulse(real a, real b, real x) real
0 if x < a or x > b, 1 otherwise.
smoothPulse(real a, real b, real c, real d, real x)
0 when x < a, smoothly interpolates up to 1 when x is between a and b, 1 between b and c, smoothly interpolates down to 0 when x is between c and d. 0 when x > d.
