SceneLoaderExcep.... a bug?
8 posts • Page 1 of 1
herodino
Post by herodino » Wed Dec 27, 2006 6:53 am
Hi to all, I tried to render a complex scene (a normal interior) assigning only to material:
light gray to all object and an rgb emitter to over 60 light :lol: but not over 61000 triangular poly
when I try to render indigo say
FATAL ERROR
SceneLoaderExcep: failed to load XML doc from path 'C:\Indigo/default.xml': Error reading end tag. Line 672, column 5
thanx to all help me :wink:
and a late Merry Christmas :D
Post by OnoSendai » Wed Dec 27, 2006 6:08 pm
I think you just have an XML tag without a closing tag.
herodino
Post by herodino » Wed Dec 27, 2006 9:57 pm
I know it. But is indigo that wrote that xml so it is an indigo problem I think. When I click render indigo export the xml than start render so how can I edit this xml? If i edit it and restart render indigo overwrite corrected xml with the uncorrect one
thanks
Post by CTZn » Thu Dec 28, 2006 12:28 am
:?: Indigo does no writing over xml's ! Indigo and the various exporters are independant softwares, not developed by the same persons. Sounds like an exporter issue, or file is too big to be written, dunno.
herodino
Post by herodino » Thu Dec 28, 2006 1:23 am
:oops: sorry it's right I confused indigo with exporter M2I but the problem still remain what I can do?
Post by CTZn » Thu Dec 28, 2006 2:25 am
np for the confusion m8 :)
The problem with me is that I'm not a 3dsMax user, I always pass by to see if there are no usefull information spreaded out concerning Indigo ;) So I can't tell you where exactly M2I put the exported scenes. Check the folders into Indigo main app folder, probably "renderscenes". If it is not here do a search (Find file or folder) created the last 24h with name *.xml, you may find it that way. Then good luck to find the line if you have just a simple text editor :D
Edit: obviously the scene is located at 'C:\Indigo/default.xml' ^_^
Post by suvakas » Thu Dec 28, 2006 10:36 am
What is your Indigo version and what is your M2I version?
herodino
Post by herodino » Thu Dec 28, 2006 9:58 pm
My indigo version is the last 0.6 and my M2I U3D-indigoExport RC0.616
I already done some render with a simple scene before had the problem.
thanx :D
Users browsing this forum: No registered users and 79 guests
