Indigo Renderer 2.4.3 Released
Post by OnoSendai » Thu Apr 15, 2010 11:08 pm
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_2.4.3_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_2.4.3_Setup.exe
See the 2.4.2 post at http://www.indigorenderer.com/forum/vie ... f=1&t=9619 for a description of the network manager.
Some more new features:
UV affine transformations
<material>
    <name>mat1</name>
    <diffuse>
      <texture>
        <uv_set>albedo</uv_set>
        <path>__55_Chevy_by_marpo3.jpg</path>
        <exponent>2.2</exponent>
        <tex_coord_generation>
          <uv>
            <matrix>1 0 0 1</matrix>
            <translation>0.5 0.5</translation>
          </uv>
        </tex_coord_generation>
      </texture>
      <albedo>
        <texture>
        </texture>
      </albedo>
    </diffuse>
  </material>
Access to elevation angles in BRDF shaders
This allows users to create fancy colour changing paints, that vary colour based on viewing angle.
There are two new functions added to the shading language, minCosTheta and maxCosTheta.
minCosTheta returns the minimum of the cosines of the zenith angles of the incident and exitant vectors of a ray scattering off a surface.
Likewise, maxCosTheta returns the maximum of the two.
You can use the return values of these functions to blend between different colours, like in the example below.
E.g.
<material>
		<name>default</name>
		<phong>
			<diffuse_albedo>
        <shader>
          <shader>
            <![CDATA[
						def eval(vec3 pos) vec3 :
                  lerp(
                    vec3(1.0, 0.0, 0.0),
                    vec3(0.0, 1.0, 0.0),
                    maxCosTheta()
          </shader>
        </shader>
      </diffuse_albedo>
      <exponent>
        <constant>
          10000.0
        </constant>
      </exponent>
		</phong>
  </material>
More shader lang functions
normalWS() Returns the shading normal for the current surface point in world space.
posOS() Returns the current surface point in object space coordinates.
Heterogeneous participating media
Participating media is stuff that scatters light - smoke, dust, snow, wax etc..
Heterogeneous means that the medium's properites can vary with position, meaning the medium can be denser in some places and less dense in others. Or it can vary in absorption colour etc..
This feature is pretty much still experimental, especially for non-uniform scattering coefficients.
Some parameters of Indigo media can now be controlled with shaders - absoprtion coefficient and scattering coefficient.
This is a pretty powerful feature, and should be able to create some pretty awesome effects.
Example:
  <medium>
    <name>medium</name>
    <precedence>20</precedence>
    <basic>
      <ior>1.0</ior>
      <absorption_coefficient>
		  <shader>
        <shader>
          <![CDATA[
							vec3(fbm(pos, 3) * 10.0)
        </shader>
          <wavelength_dependent>false</wavelength_dependent>
        </shader>
      </absorption_coefficient>
    </basic>
  </medium>
Re: Indigo Renderer 2.4.3 Released
Post by Zom-B » Fri Apr 16, 2010 12:13 am
cool!
here the missing changelog:
* Removed dependency of indigo_console on nvcuda.dll
* Made network manager stuff a bit less verbose.
Post by Pibuz » Fri Apr 16, 2010 12:31 am
Thank you guys!
I'll test this boy in minutes!
Post by suvakas » Fri Apr 16, 2010 5:44 am
Console and network rendering is working Ok now.
Post by pixie » Fri Apr 16, 2010 7:49 am
Working fine! :D
Post by OnoSendai » Fri Apr 16, 2010 2:17 pm
Added some more feature descriptions! :twisted: :twisted: :twisted:
Post by Zom-B » Fri Apr 16, 2010 3:16 pm
Whoohoo... this is quite awesome!
Now please, please with sugar on top, let fused work on Cindigo to include some of the new controls ^^
ENSLAVER
Post by ENSLAVER » Fri Apr 16, 2010 8:16 pm
The Heterogeneous participating media looks awesome.
Post by Zom-B » Fri Apr 16, 2010 11:26 pm
OnoSendai wrote:minCosTheta returns the minimum of the cosines of the zenith angles of the incident and exitant vectors of a ray scattering off a surface.
So using this I can generate a ISL based "fresnel gradient"!? This will become very awesome for carpaints and complex blendmaterials!!
I tried using this shader for blending too, but get following error:
SceneLoaderExcep: Couldn't find function eval()
btw: would it be possible to include the line in the igs where the Error appeared into this kind of messages?
Also existentially found out that a "empty function like this let Indigo crash & Burn:
def eval() real :
Post by Zom-B » Sat Apr 17, 2010 1:56 am
I had some problems with the Heterogeneous participating media.
The following code let Indigo Crash & Burn:
				<shader>
                    <shader>
                        <![CDATA[def Vec3ToReal(vec3 v) real : ((doti(v) + dotj(v) + dotk(v)) / 3.0)
					   def noise01(vec3 v) real : ((noise(v) + 1.0) * 0.5)
					   def noise01(vec2 v) real : ((noise(v) + 1.0) * 0.5)
					   def noise01(real r) real : ((noise(r) + 1.0) * 0.5)
					   def fbm01(vec3 v, int oc) real : ((fbm(v,oc) + 1.0) * 0.5)
					   def fbm01(vec2 v, int oc) real : ((fbm(v,oc) + 1.0) * 0.5)
					   def fbm01(real r, int oc) real : ((fbm(r,oc) + 1.0) * 0.5)
					   def mulCompVec2(vec2 a, vec2 b) vec2 : vec2(doti(a) * doti(b), dotj(a) * dotj(b))
					   def mulCompVec3(vec3 a, vec3 b) vec3 : vec3(doti(a) * doti(b), dotj(a) * dotj(b), dotk(a) * dotk(b))
def eval(vec3 pos) vec3: (lerp(vec3(1.00000, 1.00000, 1.00000), vec3(0.00000, 0.00000, 0.00000), noise01(mulCompVec2(getTexCoords(0) * 10.0, vec2(1000.00000, 1000.00000)))) * 1.00000)]]>
					</shader>
				</shader>
Post by fused » Sat Apr 17, 2010 3:33 am
a point inside a volume probably doesnt have a texture coordinate :)
better use 3d noise :)
Post by fused » Sat Apr 17, 2010 3:36 am
Zom-B wrote:Also existentially found out that a "empty function like this let Indigo crash & Burn:
def eval() real :
a function should return a value. but indigo should also give an error :)
Post by Zom-B » Sat Apr 17, 2010 4:53 am
fused wrote:better use 3d noise :)
well yes, totally forgot about this -.-
Now I played around a little with my first result of some 3D noise inside a few spheres:
Can you guys see the spooky face in the big sphere to O_o' ???
Here another quick render with IOR = 1:
Post by fused » Sat Apr 17, 2010 5:38 am
uhhhhhhh nice tests :)
you should try scattering to make some clouds :)
edit: that normal test is pretty cool too :)
Post by CTZn » Sat Apr 17, 2010 6:27 am
Oh great Ono, thanks for the tests Zom-B !
Users browsing this forum: No registered users and 70 guests
