Jeff
by Jeff » Tue Apr 06, 2010 7:16 am
Rendered a test animation during the long weekend. The whole scene including the vegetation was modeled inside Sketchup. The 12 sec. animation at 30fps took 90 hrs. to render. Each 720x480 frame took an average of 14 mins. to render. Compression made the video blurry. It should have been as clear & crisp as the screen grab below.
http://www.vimeo.com/10696634
Jeff on Tue Apr 06, 2010 4:50 pm, edited 1 time in total.
by StompinTom » Tue Apr 06, 2010 7:51 am
Nice man! That looks awesome!
How many different types of trees are there? What kind of machine are you using? It looks very clean for 14 minutes/frame!
Ailig
by Ailig » Tue Apr 06, 2010 8:04 am
Impressive. Your work with Sketchup, Indigo and homemade vegetation is very inspirational...
Jeff
by Jeff » Tue Apr 06, 2010 5:06 pm
Thanks a lot guys!
Tom,
There are 3 different trees on the scene. The tool used to scatter them was set to randomly rotate and scale up/down the objects to give more variety. I'm using 32 bit windows xp on a Q8200 core 2 quad @2.33 ghz w/ 3 gb ram. Each frame was set to render at 200spp. BidirMLT was used and MNCR=1000. Supersample was set at 2.
- 3D Software: SketchUp
by Pibuz » Wed Apr 07, 2010 12:40 am
Jeff
Your organic modeling skills with SketchUp are definitely on a high level!
Any chance you do a small tutorial on how you do the trees?
...or any chance you can share them?
fenerolina
by fenerolina » Wed Apr 07, 2010 9:45 am
Nice one Jeff.
Su animate plugin?
Jeff
by Jeff » Wed Apr 07, 2010 5:24 pm
Pibuz wrote:Jeff
Thanks a lot Pibuz! I might prepare some short tutorial on this one in the future. I attached the SU file for your reference. Cheers!
- 2010 forest test 2.zip
- (5.68 MiB) Downloaded 288 times
by Pibuz » Wed Apr 07, 2010 7:14 pm
fenerolina
by fenerolina » Thu Apr 08, 2010 9:26 am
Oh! how could I miss it.
djegoo
by djegoo » Sun Apr 11, 2010 5:39 am
Hi
I downloaded you file. Your Trees are really UBERquality. leaves, shapes, etc... perfect.
