If I want to render a scene with standard Indigo settings as explained in a Indigo tutorial with Indigo light tag and camera tag included, materials converted and Indigo render settings activated.
When I click Plugins -> Cindigo 2.2 Stable -> Render with Indigo, Cinema 4D crashes, screen goes semi white and it says Cinema 4D has stopped working. I run on Indigo Render v2.2.12 64 bit on Windows Vista 64 bit.
Any ideas what went wrong?
Cinema 4D crashes after IGS exporting
- c4d crashes.jpg (36.71 KiB) Viewed 4131 times
Re: Cinema 4D crashes after IGS exporting
Hey Polyman, could you send us your scene? - if it is a bit more than the 4mbs you can e-mail it to support@indigorenderer.com
Also, are you using Cinema4d 64bit?
Fused is keen to see if you found a bug
Yes I'm using the 64 bit version and I have just sent an email with the attachment.
I forgot that I can put c4d file in a rar and upload it as an attachment. Here it is.
- indigo test.rar
- (77.31 KiB) Downloaded 243 times
Hey Polyman,
which version of C4D are you using?
The scene works fine for me in R11.5 with the latest Cindigo 2.2 stable.
The sky object is not supported, can you try to turn it off and see if that helps?
I'm using 11.5 and I turned off the Sky object and still, Cinema crashes after clicking on Render with Indigo.
- PureSpider
loomisgroup
I have the same issue... cant get indigo to render, or export IGS.
I'm using C4D r11 and indigo 2.2 for r11 on Mac os10.6
I've tried on older scene, or just creating a new one with a single object. I've checked permissions on the directories, and everything should be good.
Thanks
Jeff
Thanks
Jeff
