Blendigo 2.2.11-d
8 posts • Page 1 of 1
dougal2
Blendigo 2.2.11-d
Post by dougal2 » Mon Jan 11, 2010 3:48 am
This version can be considered Release Candidate 4 for Blendigo 2.2 stable. Please report show-stopping bugs only.
Windows
http://www.indigorenderer.com/dist/expo ... taller.exe
Linux
http://www.indigorenderer.com/dist/expo ... 1-d.tar.gz
OSX
http://www.indigorenderer.com/dist/expo ... 2.11-d.zip
Changes in this release:
* fix limits for exponent (C) parameter.
* Fix bump map mm -> m scaling.
* back-ported motion blur fixes to 2.2 branch.
* translate 'UVTex' to 'default'
* Fix incorrect CRF path string
Jambert
Re: Blendigo 2.2.11-d
Post by Jambert » Mon Jan 11, 2010 7:00 pm
Thx :D
Post by StompinTom » Tue Jan 12, 2010 12:32 am
Wicked! Testing...
enricocerica
Post by enricocerica » Thu Jan 14, 2010 5:56 pm
Hi Dougal2,
Did you already included something regarding the lens shift ?
Could you say more about 'Fix incorrect CRF path string' ?
Thanks
Jambert
Post by Jambert » Thu Jan 14, 2010 7:22 pm
enricocerica wrote: Did you already included something regarding the lens shift ?
I just tried, it works :wink:
Jambert
Post by Jambert » Thu Jan 14, 2010 7:43 pm
Dougal2, don't now if it's realy bug coming from blendigo, alpha render doesn't work with black background color.
Req: Would be nice if it was possible to add "none emiting background" or "lit by mesh emitters" as an option to use with "background colour", "env map" and "sun sky". A render mode with a background but not emitting. Can be usefull to render transparent object without using white mesh in background... or just to make light setup easier. Is it possible to do it?
thx
dougal2
Post by dougal2 » Fri Jan 15, 2010 12:40 am
@jambert
there is a possibility to use a material as the background. It's on the TODO list.
@enrico
I found an error in the camera response function file code, that I fixed. It looked like a good candidate for the error reported about CRF files not working on non-windows systems. If the error is not fixed, please let me know.
Jambert
Post by Jambert » Fri Jan 15, 2010 1:55 am
dougal2 wrote:@jambert
Great thx :D
