Fur test
11 posts • Page 1 of 1
filippo
Fur test
Post by filippo » Wed Feb 18, 2009 2:44 am
Hello all, i realized this first test to make the fur....
I used the module hair & fur of 3dmax , do you know other methods?
I hope that you like it
filippo
this topic it's also in other topic
fur
test fur1.jpg (620.47 KiB) Viewed 14528 times
Post by suvakas » Wed Feb 18, 2009 5:24 am
Nope, don't know any other methods for doing fur in Max.
You can also use it for things like grass and etc.
Here's my small test I made with Hair & Fur (rendered in Indigo of course).
Not very photoreal from close up, but should be quite ok from the distance.
Post by CTZn » Wed Feb 18, 2009 11:44 am
Nice test suvakas ! In fact, apart the shader it's really looking good, shadows are just too strong and material a bit dull. Fur is doing well !
Post by suvakas » Wed Feb 18, 2009 6:40 pm
Thanks CTZn!
I can only do diffuse material in current "work in progress" Maxigo.
No other shaders or textures yet. :)
Slavn
Post by Slavn » Thu Feb 19, 2009 5:56 am
Is it a new pre beta exporter testing? :shock:
Post by suvakas » Thu Feb 19, 2009 6:44 am
Yep :)
Post by Pibuz » Thu Feb 19, 2009 6:52 am
...for Max2009?
Post by suvakas » Thu Feb 19, 2009 7:01 am
I don't have 2009, but I will download the trial and test before the release. Older scripts should run just fine on new Max versions though.
filippo
Post by filippo » Fri Feb 20, 2009 10:55 pm
I ido not understand if you are creating the new versio maxigo with this feature.
as you realized your test?
filippo
Slavn
Post by Slavn » Sat Feb 21, 2009 12:04 am
suvakas wrote:Yep :)
Wow :D Very good.
Post by suvakas » Sat Feb 21, 2009 12:20 am
filippo wrote:I ido not understand if you are creating the new versio maxigo with this feature.
filippo
No, it is standard Hair and Fur and not a new feature.
The scene is exported using my work in progress Maxigo version, but it doesn't really matter.
