								winnabago111
								by winnabago111 » Wed Aug 13, 2008 6:23 am
			I am trying to export a glowing sphere into indigo but when i export it, it just comes out black. I turned emit up to .7 and nothing changes. Does it have something to do with the exporter.
								zsouthboy
								by zsouthboy » Wed Aug 13, 2008 7:29 am
			More than likely you have a tonemapping problem.
Try switching to linear tonemapping.
								by Borgleader » Wed Aug 13, 2008 8:59 am
			winnabago111 wrote:Where is that button located?
Blendigo -> Tonemap
Duh
Nea the bottom you'll see a dropdown menu with "Reinhard" on it. Switch it to Linear.
								5OnIt
								by 5OnIt » Wed Aug 13, 2008 2:26 pm
			Would be a good idea as well to make sure your normals are pointing in the right direction.
Also - Are you just using the Emit values in blender and expecting them to work in Indigo? You have to specifically set an Emitter Material in Blendigo if that's the exporter you're.
								winnabago111
								by winnabago111 » Thu Aug 14, 2008 9:34 am
			I am using blendigo. I changed the tonemapping and under materials i choose Emitte=lights+meshes. It still comes out with no light coming from the sphere. Should i get rid of my light source(sun) would that help.
								zsouthboy
								by zsouthboy » Thu Aug 14, 2008 10:07 am
			Yes, that is the problem - change the environment to None.
The sun is millions of times more powerful than your emitter right now.
								Richiev
								by Richiev » Tue Aug 19, 2008 2:46 am
			On the same topic: when in Blendigo I set a material to emit and hit render it returns error:
No 'spectrum' element found in meshlight element.
This message is not familiar to me, does someone know what I am doing wrong?
I use Blender 247rc2 (also tried 246), Indigo 1.1.7, Blendigo 1.1.7
