Olis
by Olis » Tue May 06, 2008 1:34 am
I simply wanted to render something orange. I made this simple shape just to give it an orange material. The metal cylinder on which it stands, has a bumpmap I made in photoshop. The strange thing is, that even though it's smoothed, the polys are visible at the right of the cylinder. Well, here it is. No postpro.
Updated version:
Olis on Sat May 10, 2008 2:32 am, edited 2 times in total.
dougal2
by dougal2 » Tue May 06, 2008 1:40 am
nice, however seeing as you have photoshop, please use "Save for web" on your renders in future... that image is massive and took over a minute to load here.
by Kram1032 » Tue May 06, 2008 2:59 am
did you check for double verts?
Olis
by Olis » Tue May 06, 2008 3:38 am
There. Now I have rehosted it.
@Kram No, I don't think there are any since it's just a beveled cylinder.
by Kram1032 » Tue May 06, 2008 6:31 am
directly from the primitive?
That's strange...
Oh, wait. Did you bevel each face (using the bevel-tool) or only those on the right angle at the top?
Olis
by Olis » Tue May 06, 2008 6:33 am
No, I used the "bevel center" script on the circular edgeloops.
by Kram1032 » Tue May 06, 2008 8:18 am
ah, I see... ok, I ran out of ideas
The only thing I can think of is that it simply isn't round enough... - though then the whole thing should be affected and not only that part....
An idea: you can try to use the cast modifier with a vertex group on the non-bevelled, perfectly cylindrical part, to cylindrify the mesh
Olis
by Olis » Tue May 06, 2008 5:01 pm
Perhaps, but right now the cylinder has 64 sides. I'm making a new one with 256.
Olis
by Olis » Wed May 07, 2008 9:27 am
I am now rendering it @ 2560 x 1440. Just like the first one only this one will (hopefully) look better
Olis
by Olis » Thu May 08, 2008 2:38 am
Here is the new version with 17h rendertime. There seems to be quite a ray trap inside and underneath the orange thing.
by PureSpider » Thu May 08, 2008 4:02 am
may we have your brushed bump map?
Olis
by Olis » Thu May 08, 2008 8:19 am
by PureSpider » Thu May 08, 2008 9:00 am
thanks!
by CTZn » Sat May 10, 2008 12:25 am
Yep it is. Is it used for bump only or for exponent also ?
