Dining table
blackice55
Dining table
Post by blackice55 » Wed Feb 27, 2008 10:05 am
Hello I start this but I d'ont like the result... I know that I need more object. Do you have sugestion to have a more realistic lghting? I will change the lampe on the top for a other thing its seem to weird.
Post by pixie » Wed Feb 27, 2008 10:33 am
First I'll have to ask you what kind of chair you have on the left! :-P
Post by Kram1032 » Wed Feb 27, 2008 10:33 am
the light will also get better with more objects in the room ;)
Please don't use THAT high jpg compression...
Oh, and it looks like your table cloth could need a bit of retouching, especially at the angles of the table...
psor
Post by psor » Wed Feb 27, 2008 10:34 am
@blackice55
I dunno mate, ... if you use the "physical sky & sun" then you've a very
realistic lighting there. The only thing you would have to change is the
materials and maybe the camera settings. And for the log, a professional
photographer will use fill lights and bouncers to make the image look like
it looks in a catalog or high glossy magazine. So please explain a bit
more what you're after. ;o))
take care
psor
"The sleeper must awaken"
blackice55
Post by blackice55 » Wed Feb 27, 2008 1:15 pm
Yea for the weird chair I forgot to put deflection on it... I use the svn built of blender with new cloth simulation, But I dont obtain good result... That bug all the time...
I do an other render with reduce reinhard power...
http://www.indigorenderer.com/joomla/in ... emId=24550
Well do I should put curtains on the windows?
Vampyre
looks good so far
Post by Vampyre » Thu Feb 28, 2008 6:07 pm
I would put base boards on the wall where the wall joins the floor
like these
http://www.smithtrim.com/Brodia_baseboard.JPG
is your table cloth subsurf ? that might help
i like the lighting but it looks kind of unreal. curtains would help alot. maybe use a transparent diffuse material for the curtains?
otherwise it looks really good. im looking forward to seeing the finished image
blackice55
Post by blackice55 » Sat Mar 01, 2008 5:15 pm
Hello I just change the angle of camera and wall color + tone map and i obtain this. In the next render i will put curtains, a corect texture and other modelisation. Thx for your help.
muody
Post by muody » Sat Mar 01, 2008 10:22 pm
why the floor texture is so... random? looks really strange, like a one huge piece of wood. I know, it may be a linoleum, but render - opposed to photo - must make us believe it's real. find some textures of wood, cut several rectangles and join them into a seamless tex
as for lighting, I would add a one emitter to the scene, on the left. some lamp with 'diffuse transparent' on it, to make it more interesting
blackice55
Post by blackice55 » Mon Mar 03, 2008 8:34 am
hello little update!
do you like this ambiance? And on the wood floor do I should put bump? Thx for your help!
blackice55
Post by blackice55 » Thu Mar 06, 2008 6:11 pm
Vanessa07
Post by Vanessa07 » Thu Mar 06, 2008 7:41 pm
good work :)
Maybe you should add some curtains and open a window to make your scene a bit more "animated"
kwez
Post by kwez » Sat Mar 08, 2008 5:15 am
niiiice, keep it up.
is it a part of the table 'poking through' the table cloth in the front ??
blackice55
Post by blackice55 » Sun Mar 09, 2008 12:35 pm
I add curtains :P Sorry for the bad quality render.
blackice55
Post by blackice55 » Mon Mar 10, 2008 3:34 am
blackice55
Post by blackice55 » Thu Mar 13, 2008 1:26 pm
no comment? :(
