Hello:
I am completely new to this. I got indigo up and running. I did a simple light element and glass plate sculpture thing in SU and it is still rendering 4 hours later. Everything is the default except the background is black. I am running it on a mix of things. The machine is the newer mac book pro with parallels running indigo. I know that it is slower then the have it dual boot. But 4 hours seems a little long. Any suggestions or I just should wait and see what will happen. attached in a screen shot. It just keeps on running. Any help would be much appreciated.
Thanks
How long should it take to render
- light_house_1st_test.jpg (13.91 KiB) Viewed 7786 times
yes, indigo does run until you stop it.
the number you want to watch is the "Samples per pixel" value, or keep a close eye on the grain/noise in the picture.
The more samples you have the better, generally - although over 2000 - 3000 samples might be unnecessary for some scenes.
Some scenes can take many hours or days to reach that level of quality.
Thanks for the info:
Display took 0.45115 s
Time elapsed: 5 h, 3 m, 53 s
Done 708930000.00000 samples (5189.25447 samples per pixel)
38880.56423 samples / second (25.71979 micro-seconds / sample)
This is what I got. The sample per pixel is higher then 3000. I guess this is good.
Thanks I will keep waiting.
On another topic do you know how to make a direct spot light from a cylinder object. or point me to a thread that is already out in the forum.
Thanks again. The results from the gallery look like the wait is worth it.
