[REQ] Render only a portion of an image
5 posts • Page 1 of 1
Dusan
Post by Dusan » Sun Nov 04, 2007 11:19 pm
It would be very useful if it were possible to render only a certain (e.g. rectangular) portion of the entire image.
In case when just a small detail in the scene was changed, it wouldn't be necessary to re-render the entire image again. 8)
Thanks.
Post by Kram1032 » Mon Nov 05, 2007 12:47 am
It would be useful for showing bugs, yeah, but for what you're saying, it wouldn't be that useful, I guess:
what about the radiosity in diffuse materials?
what about the reflections?
It depends, *how* small the change is, for sure, but usually, if you don't want to show a special bug, rerendering the whole thing should be better ;)
Dusan
Post by Dusan » Mon Nov 05, 2007 2:26 am
I understand your point, on the other hand there are many cases when re-rendering the entire image (overnight or even longer) is just not necessary.
manitwo
Post by manitwo » Mon Nov 05, 2007 2:28 am
+1 dusan.
Post by CTZn » Mon Nov 05, 2007 3:11 am
+1, as usual. I always do a lot of testing before final render, who doesn't ? Best workaround I found so far was to set the display time to 1. As you want a rapid feedback, refreshing cycles are negligible, cpu wise, in this case.
Note that rendering region was already requested in various threads here ;)
