How to run Indigo in a lower priority mode automaticly
Tutorials/guides/tips on how to use Indigo and the Indigo exporters
9 posts • Page 1 of 1
CoolColJ
Post by CoolColJ » Wed Sep 12, 2007 7:55 pm
If you want to use all your CPU threads without lagging your system while Indigo renders - then you need to lower it's priority
you can set Indigo into a Below Normal priority automaticly in Windows XP
1) right click on Indigo's icon and create a new shortcut
2) right click on the shortcut and select properties
3) in the target field add this line in front of the existing info
C:\WINDOWS\system32\cmd.exe /c start "Indigo" /belownormal
just rename this new shortcut to something like Indigo_below_normal or whatever and double click on it to start Indigo in below normal priority mode
it does run a little slower, but not by much if your not doing anything
sorted 8)
CoolColJ
Post by CoolColJ » Wed Sep 12, 2007 8:01 pm
if you want to revert back to normal priority -
then hit Ctrl+Alt+Delete to bring up the windows task manager
go to processes and find Indigo, or just hit CPU field, which should show Indigo at the top or bottom
right click on it and select a new priority
Post by OnoSendai » Wed Sep 12, 2007 8:04 pm
Nice tip, mind if I move to tutorials section?
CoolColJ
Post by CoolColJ » Wed Sep 12, 2007 8:07 pm
sure go ahead :)
zsouthboy
Post by zsouthboy » Thu Sep 13, 2007 1:07 am
Easier way:
Right click in indigo folder -> "New" -> "Text Document" -> type indigo.bat -> hit enter twice -> type START /BELOWNORMAL indigo.exe default.igs => save and exit
...Well, it doesn't look easier when I type it all out, I guess :P
neepneep
Post by neepneep » Thu Sep 13, 2007 5:59 am
CoolColJ wrote:then hit Ctrl+Alt+Delete to bring up the windows task manager
Using CTRL-SHIFT-ESC might save you one click :D
oogsnoepje
Post by oogsnoepje » Thu Sep 13, 2007 8:23 am
Right clicking on an empty area of the taskbar and choosing Task Manager gets you the task manager without a touch of the keyboard at all :P
There's also no specific column you have to click on.
CoolColJ
Post by CoolColJ » Thu Sep 13, 2007 10:05 am
clicking the column is just to bring up Indigo, instead of scrolling around looking for it, since it's the highest CPU user
oogsnoepje
Post by oogsnoepje » Thu Sep 13, 2007 1:21 pm
Haha, allrighty, I didn't really understand what you meant with top and bottom, it's clear now ;)
*sleepy
