Indigo 0.9 test 3
Indigo 0.9 test 3
http://www.indigorenderer.com/montecarl ... _test3.zip
Changelog:
* improved XML handling so comments inside bottom level elements are ignored.
* made transform matrices be arbitrary
* added halt_samples_per_pixel in inifile
* added halt_samples_per_pixel element in renderer_settings in scene XML,
* added -haltspp X command line switch
* fixed albedo_spectrum for diffuse_transmitter
* misc. performance enhancements.
The halt samples per pixel option(s) allow you to terminate the Indigo program after a certain number of samples per pixel have been computed.
This can be a more appropriate termination condition than time since program start in some cases.
Changelog:
I haven't really understood what halt_samples does yet, could you explain it a little bit more is it something like stopping a render or what? You've made really nice and cool stuffs in 0.9 Ono thanks
- Kosmokrator
put something like this in .bat file Tweeby: (if ur on windows)
set indigopath=.\indigo_console.exe
set testscenepath=\\lust\models\testscenes
set args=-t 1 -halt 36
%indigopath% "%testscenepath%/globe_test.igs" %args%
%indigopath% "%testscenepath%/exit_portal_test.igs" %args%
%indigopath% "%testscenepath%/simple_bump_test.igs" %args%
