would this be at all useful...
- Kosmokrator
- Kosmokrator
It shows the distribution of luminance in the image. In the example, it is showing that the vast majority of the image consists of pixels that are fairly dark.Kosmokrator wrote:about the histogram....i dont understand the use of this graph...?
To the left of the histogram is dark values, and to the right is light values.
- Kosmokrator
hhmmm ok i understand but i dont see how this can help for image calibration....anyway i think may this visual represent may help somehow!
it'll show up if you're clipping your whites
more info: http://www.cambridgeincolour.com/tutori ... grams2.htm
- Kosmokrator
mrCarnivore
Nice solution of the space issue with tabs!
The histogram is a nice addition but only in combination with the tonemapping settings, imho. All the other settings only affect the histogram slightly. Also the histogram can be made much, much smaller! I think 150 x 75 pixels or so should be enough to get all the information you need from the histogram.
I would suggest you place the histogram directly in the tonemapping tab. If it's that small it should fit nicely.
mrCarnivore
Doesn't necessarily have to be 256 pix wide. The single values are not that important. The overall form is much more important.
Nice position for the hist. You should change to colour to black/white though!
I see no need for having a seperate histogram for each colour.
But if you did, you can use the corresponding colour for the hist colour. Then you could display them all at once with mixing the colours. Might lead to a very colourful information display that is totally unreadable, though.
we could have a set of radio buttons for the histogram type:
o Red
o Green
o Blue
o Luminosity ( = 0.33R + 0.56G + 0.11R)
changing the colour to white is an easy one (or, perhaps 50% grey
Other things that I'll show you lot soon include:
a couple of denoising filters, and the return of linear tonemapping.
o Red
o Green
o Blue
