[ISL Help] Concentric circles
12 posts • Page 1 of 1
Originalplan®
Post by Originalplan® » Thu Jan 19, 2017 4:04 am
Hey guys & girls.
What is the simplest *easiest way to create concentric circles via ISL on mat surface...dozens of them??
Thank you!
:oops: :oops:
Re: [ISL Help] Concentric circles
Post by lycium » Fri Jan 20, 2017 2:14 am
I was getting a little rusty in ISL, so it was good to brush up again :) Even found a crashbug in the shader editor along the way!
Without further ado, your material, sir: http://www.indigorenderer.com/materials/materials/1656
Originalplan®
Post by Originalplan® » Fri Jan 20, 2017 2:26 am
@lycium THANK YOU!
Post by lycium » Fri Jan 20, 2017 2:30 am
No problem, and thanks Yves/fused for helping me out :)
Post by pixie » Fri Jan 20, 2017 2:34 am
Do you want anisotropy? Because that's how'll get anisotropy! :P
Post by lycium » Fri Jan 20, 2017 2:38 am
Yeah it works off the UV map, so I guess it won't be circles unless the UV map is perfect / undistorted. It's possible to modify it to use the worldspace position or angles or something like that to get around this, but then your object also has to be perfectly aligned.
In any case, let me know if you need any changes.
Post by pixie » Fri Jan 20, 2017 2:49 am
lycium wrote:Yeah it works off the UV map, so I guess it won't be circles unless the UV map is perfect / undistorted. It's possible to modify it to use the worldspace position or angles or something like that to get around this, but then your object also has to be perfectly aligned.
I cannot get the shader to work on the bump channel, it goes haywire!
aniso3.zip
(572 Bytes) Downloaded 609 times
Post by lycium » Fri Jan 20, 2017 3:13 am
Hmm, I'm not sure exactly what effect you're looking for now. As it is the shader is not really suited to bump mapping, because of that instantaneous change in colour / height; furthermore, the bump map shader expects a single value (real / scalar) and not a colour / vec3.
Try messing with this code in the bump shader:
def eval() real :
	let
		c = getTexCoords(0)
	in
		#1 - pow(sin(length(c) * 64) * 0.5 + 0.5, 117)
		1 - pow(sin(length(c) * 14), 117)
You can tune the numbers as before in the shader editor, and you can try the other commented line to see if it's maybe more like what you want (put the # before the 2nd line and remove it in the first line after the "in").
Post by pixie » Fri Jan 20, 2017 3:36 am
lycium wrote:Hmm, I'm not sure exactly what effect you're looking for now. As it is the shader is not really suited to bump mapping, because of that instantaneous change in colour / height; furthermore, the bump map shader expects a single value (real / scalar) and not a colour / vec3.
def eval() real :
	let
		c = getTexCoords(0)
	in
:D Sadly it doesn't work on GPU
Post by lycium » Fri Jan 20, 2017 4:09 am
Yeah I noticed that the bump shaders aren't working on GPU at the moment. Pending investigation :)
Originalplan®
Post by Originalplan® » Fri Jan 20, 2017 4:25 am
lycium wrote:No problem, and thanks Yves/fused for helping me out :)
8) !
lycium wrote:Pending investigation :)
Post by pixie » Sun Mar 17, 2019 1:04 am
It is working now on GPU :)
