Infinite White and Light Intensity
Come here for help & support.
4 posts • Page 1 of 1
Tom Zandt-Valentine
Post by Tom Zandt-Valentine » Tue Nov 03, 2015 2:44 am
So I am fairly new to the renderer and have a couple of questions which I am hoping you guys could help me with.
I am trying to display a product on a white background whilst having shadows and a reflection on the floor. In C4D I would usually use the compositing tag with a background object in order to 'catch' shadows however this doesn't work with indigo.
I deleted the background object and then swapped to the built in environment settings and followed the tutorial on compositing with shadow pass: http://www.indigorenderer.com/documenta ... s-tutorial
So here are my questions.
1. Is there a way to just add a shadow catcher without having to composite afterwards as I would with the compositing tag normally?
2. How do I adjust the intensity of the RGB lights as i cannot find a control for them?
Im using the reinhard method and so i fear the light adjustments are not showing up, however if i change to linear or camera then the scene just goes black?
Thanks
Tom
Silverwing
Re: Infinite White and Light Intensity
Post by Silverwing » Tue Nov 03, 2015 4:06 am
Hi Tom,
I unfortunately can´t tell you how to comp with Indigo or if its even possible.
Just a small note that you probably also know:
As reflections are comped additive you probably only will see them in shadow areas (when having a white background)
I at least might help you to set up a linear scene. e.G. getting things (near) overexposed:
The light sources are generally pretty weak. Therefore you get a black render when setting the global light mapping settings to linear. I have attached a scene with a linear output settings. Hopefully this will help you to at least answer some questions.
Edit:
Sorry was not aware that you also need the meshes that come extra... Exchanged the scene with hopefully now all assets!
Cheers,
Raphael
Linear_Scene.rar
(6.14 KiB) Downloaded 393 times
You don´t dream in cryo.
Post by Oscar J » Tue Nov 03, 2015 9:04 am
Silverwing, you have to save as .pigs to get all the files packed. :) Can't open the attached scene, unfortunately.
Post by Oscar J » Tue Nov 03, 2015 9:08 am
Also, unfortunately it is not currently possible to use the shadow catcher without compositing.
