exit portals / exposure / bi d paths etc / sketchup
3 posts • Page 1 of 1
Jelko
Post by Jelko » Thu Aug 20, 2015 10:34 am
So I was just test rendering with exit portals fine at work on unlicensed for sketchup
Everything looked good
Now I come home and open saved file I was just working on and camera won't work, only reinhard..
when trying to use render in camera setting nothing shows up but the exit portals...
Is some setting changed within my RT license? What should I be looking for.
both settings worked before, now only reinhard
thesquirell
Re: exit portals / exposure / bi d paths etc / sketchup
Post by thesquirell » Thu Aug 20, 2015 10:49 am
When something works in Reinhard tone mapping mode, and not in others, it usually means that your light power balance is off, and that you should: a) Increase the light power; b) Switch to camera mode, and adjust film ISO, or/and EV value. You could also pay attention to the camera's exposure time (measure is (1/s), so go for value 1 or 2, greater values of 1600, or 800 will make your image look darker because your film get's exposed for a shorter amount of time). Your light portal is only visible because it is probably the brightest source of light in your scene. If that's not the case, you should check the normals of your exit portal plane. That's my guess, hope it helps.
Jelko
Post by Jelko » Thu Aug 20, 2015 2:55 pm
thesquirell wrote:When something works in Reinhard tone mapping mode, and not in others, it usually means that your light power balance is off, and that you should: a) Increase the light power; b) Switch to camera mode, and adjust film ISO, or/and EV value. You could also pay attention to the camera's exposure time (measure is (1/s), so go for value 1 or 2, greater values of 1600, or 800 will make your image look darker because your film get's exposed for a shorter amount of time). Your light portal is only visible because it is probably the brightest source of light in your scene. If that's not the case, you should check the normals of your exit portal plane. That's my guess, hope it helps.
Perfect.. I didn't realize I had to bump everything up that much.. but it's looking rrrreally good now, thanks!!!!!!!
Users browsing this forum: No registered users and 46 guests
