Help with bumpy shiny surface
12 posts • Page 1 of 1
Bosseye
Post by Bosseye » Thu Jul 02, 2015 2:23 am
Hi there,
I've been struggling with this for a while; can anyone give me some tips on how to make a simple bumpy shiny surface like the image below?
I've been trying to apply a simple bump map to a shiny surface with no luck - the UV scaling is too small and I can't figure out how to get it larger (despite writing a tutorial on here a little while back for how to set UV mapping in Sketchup...! Even following my own steps it simply won't work).
Maybe because its a curved surface, I don't know.
Anyway, some help would be appreciated.
bumpy glass.JPG (16 KiB) Viewed 12011 times
Thanks,
FakeShamus
Re: Help with bumpy shiny surface
Post by FakeShamus » Thu Jul 02, 2015 5:58 am
I'm not a skecthup person, but my go-to random bumpy surface is always done as an ISL shader:
def eval() real:
noise(posOS()*100)*0.0001
start from there and change the posOS()*value (higher number makes smaller bumps, lower means larger).
and the 0.0001 value controls the height of the bump - sometimes this needs to be very small in order to look correct.
Bosseye
Post by Bosseye » Thu Jul 02, 2015 8:33 pm
Hey thanks for that - I've never touched ISL before though, is this something I would have to do via the Material Editor? For some reason I don't have that installed.... :?
Post by CTZn » Thu Jul 02, 2015 9:23 pm
In the SkIndigo material editor, change the map type for bump from texture to shader, and there you go.
Shaders can be edited in real time while rendering in Indigo. You can also change the texture scaling in the Indigo texture editor, it's weird but change the two "1" arranged in a square with zeroes to a different value.
Try it and tell back :)
Bosseye
Post by Bosseye » Thu Jul 02, 2015 10:04 pm
Hey this is cool! Managed to mess it up initially though, I just added this line:
underneath the def eval which was already filled in like this:
def eval() real : fbm(posOS()*4.0, 2)*0.02
#This is a fractal noise shader.
#4.0=Position scale
#2=fbm octave
#0.02=multiplier (eg. height for displacement
And ended up with this:
Which is cool but wrong!
And then I engaged my brain and removed the def eval code and just added the code exactly as FakeShamus had noted and I get this:
Which is much better!
So with a little bit of fiddling, I get this:
Which I think is just about right (aside from the colour which I will tweak). The bump won't be so obvious when the material is in the rest of the scene and properly lit.
Thank you both so much, you've really helped me out.
Post by Pibuz » Tue Jul 21, 2015 3:49 am
I'd have used the ISL too to get the right result, even if I don't know almost anything about it :lol:
...I actually think that sooner or later some sort of graphic controller will have to be integrated in order to get all users understand and USE the ultrauseful ISL (I don't know: primary functions such as fractal noise, noise, speckle and so on to be chosen from a list, and then sliders to adjust the scale and power of the shader..)
In your case, I'd have also tried to map the surface using a simple sketchup material with the bump texture as diffuse map. Then, in the material editor, switch the albedo slot from SU to NONE and select that blue/green-ish tint to colour you surface. This way you could still use the bump texture referenced to SketchUp mapping without having to fiddle around with it. Did you think about it?
bubs
Post by bubs » Tue Jul 21, 2015 8:08 pm
Bosseye wrote:I don't know: primary functions such as fractal noise, noise, speckle and so on to be chosen from a list, and then sliders to adjust the scale and power of the shader..
+1 8)
Post by Zom-B » Tue Jul 21, 2015 11:07 pm
Just like fused did for the C4D exporter:
Post by Oscar J » Tue Jul 21, 2015 11:28 pm
WTH! Why does Indigo not have that? :shock:
Post by Zom-B » Wed Jul 22, 2015 12:00 am
Oscar J wrote:WTH! Why does Indigo not have that? :shock:
This is a "simple" GUI that controls some ISL Shader parameters inside C4D.
Indigo does have something like that, but for that some artist/coder needs to setup the material nicly in the first place!
Like the material in this thread: http://www.indigorenderer.com/forum/vie ... 23&t=13032
Post by Pibuz » Wed Jul 22, 2015 12:29 am
I WANT THAT FOR SKINDIGO! :lol:
Juju
Post by Juju » Wed Jul 22, 2015 12:39 am
Pibuz wrote:I WANT THAT FOR SKINDIGO! :lol:
+1!
