Alpha channel of material from R14 to Indigo get a bug?
2 posts • Page 1 of 1
butaixianran
Post by butaixianran » Fri Jan 02, 2015 4:38 pm
Alpha channel of material from C4D R14 to Indigo won't work.
I find that indigo plugin create 2 materials for a material with alpha in C4D, let's say they are: materialX and materialX_BlendA. The materialX is a blend type material which invokes materialX_BlendA(type: Phong).
The problem is:
To make alpha channel works in Indigo, the materialX (type: blend) should be assigned to mesh. But when I click Render with Indigo in c4d plugin, the materialX_BlendA is assigned to C4D and leave materialX unused.
So the alpha won't work in Indigo unless I re-assign these materials.
Is that a bug of Indigo for C4D plugin, or it's something wrong of C4D, or even my own bad??
Thanks.
riley1389
Re: Alpha channel of material from R14 to Indigo get a bug?
Post by riley1389 » Sat Jan 10, 2015 2:18 pm
Have you tried the "Step Blend" option? And the order of which material is the base does matter. I wish I could help more, but I'm having a little bit of a problem understanding it.
Also, another thing you coulf try is to assign the same texture to both material_x and material_x Alpha or whatever. Because the texture is already mapped to the mesh, the coordinates will still be applied to both materials.
Users browsing this forum: No registered users and 82 guests
