I work mainly with bitmaps but to achieve the render results they almost always need tweaking in Indigo.
When I go to the material editor section there is an "Open Image" which basically opens the texture map in its original state (unedited in Indigo)
Is there a way to export the materials as they are after tweaking in Indigo?
Many Thanks in advance.
Exporting Maps post editing in Indigo?
- trutextures
Re: Exporting Maps post editing in Indigo?
At the top left of the properties panel there is a little 'file' icon. Click on this and you get a drop down with save material options. You can save as a .pigm and the image files will be packed to the saved matetial
