bug and fix in MtI 3.6.17 diffuse transmitter
4 posts • Page 1 of 1
zio
Post by zio » Mon Jun 16, 2014 10:04 am
MtI 3.6.17 gives an an error when you export diffuse transmitter material->random_triangle_color error
so replace
		$mti_GEN_diffuse += "\t\t<random_triangle_colours>"//true
							+	mti_GEN_boolToString($randomTris)
							+	"</random_triangle_colours>\r\n";
in line 493 with:
		if($randomTris)
			$mti_GEN_diffuse += "\t\t<random_triangle_colours>true</random_triangle_colours>\r\n";
that is what was in previous version.
Maybe CTZn placed that middle code by mistake, I do not know, do you?
EDIT: I forgot to tell the file name->mti_GEN_.mel
previously ior
Re: bug and fix in MtI 3.6.17 diffuse transmitter
Post by Zom-B » Mon Jun 16, 2014 11:53 am
afaik "random_triangle_color" is only available for diffuse materials...
zio
Post by zio » Mon Jun 23, 2014 4:35 pm
It seems that everything is fine with the code I reverted to.
Random triangles also work with dif transmitter?
Do not know what that code was doing there. Anyone?
previously ior
Post by CTZn » Tue Jun 24, 2014 5:25 am
the code is not wrong in itself. it writes the random triangle status wether it's true or not. the lines you are using wich are found in different places of the same file, writes it only when it's true. not sure what is going on with the diffuse transmitter but as told random triangles are a diffuse option that goes hidden when using the indigo editor for diff trans.
