Indigo is not working with max9
I installed everything according to the tutorials, readme files and videos. put the name of the dir in the inifile but everytime i hit render it export the scene and open the picture viewport and indigo shows an error message:
"indigo.exe has detected a problem and most be closed".
I am using indigo M2I616f with 3dmax9 on athlon xp64 3.2 + 2 gig ram DDR2 on MSI 940 motherboard with n-vidia geforce 7300 pci-express 256 DDR2
Are all your objects mesh's? Do they all have an indigo material? and do you have a mesh object with an emiter material?
Website
http://www.surrient.com/
- afecelis
you must use Indigo 0.6 official. The latest Max2Indigo only works with that version. Indigo 0.7 has a completely new material system and xml syntax for which exporters for all major 3d apps used need to be rewritten.
But many have successfully used Max9 and U3dreal's Max2Indigo.
Re: Indigo is not working with max9
indigo 0.6 work very well on max9, if you have the problem, you can post it in this forum..Vancliff wrote:I installed everything according to the tutorials, readme files and videos. put the name of the dir in the inifile but everytime i hit render it export the scene and open the picture viewport and indigo shows an error message:
sorry for my language
indigo gira bene su max9,se hai dei problemi, postali qui..
filippo
It works now in max9
Is working properly now and is rendering really fast
