- Material preview
- Area lights, square and rectangle with size adjust (basically meshlight planes but easier and quicker to setup)
- Export individual mesh to indigo external mesh
- Coating panel for materials
- Spotlight, maybe spotlights are not supported but perhaps a workaround via automatically generated IES? Spotlights are useful for positioning due to the interaction and visibility in interface
- Manual viewport colour override
Blendigo Wishlist
Blendigo Wishlist
Hi I don't see a blendigo wishlist thread so I will start
Re: Blendigo Wishlist
- Export individual mesh... : This is already possible. Select the desired mesh, go to File > Export > Export IGMESH (or similar, haven't got it open).William wrote:Hi I don't see a blendigo wishlist thread so I will start![]()
- Material preview
- Coating panel: Thought this was put in recently?
Otherwise, yes, it would be good to see the rest of those!
Cool! did not knowStompinTom wrote:- Export individual mesh... : This is already possible. Select the desired mesh, go to File > Export > Export IGMESH (or similar, haven't got it open).
There is a coating material but you need to specify the base material (subsequently needing two materials)StompinTom wrote:- Coating panel: Thought this was put in recently?
I'm talking placing the coating like this
Live Viewport Preview !!!!! Like we saw it in Cindigo or OtoyBlender. Might not be the fanciest feature, but for the workflow it would be quite a hack!
FakeShamus
this way would make a lot of sense.William wrote: There is a coating material but you need to specify the base material (subsequently needing two materials)
additionally, I would like to see null materials with emission properties available, now that it's possible in Indigo. (with back-face emit option, too!)
+1. The single most longed for exporter feature me thinks. It's 2014 after all.steven369 wrote:Live Viewport Preview !!!!! Like we saw it in Cindigo or OtoyBlender. Might not be the fanciest feature, but for the workflow it would be quite a hack!
- zeitmeister
Blendigo Wishlist
No? You could simply activate it in c4d...
"Preview region" or something like that.
Grüsse, zeiti
Grüsse, zeiti
The idea behind a live preview is that the renderer don't need to "rebuild" the whole scene again (like calculating subdiv, sample the HDRI, build BVHs etc.)zeitmeister wrote:No? You could simply activate it in c4d...
At the moment C4Ds RegionRender does exactly that :/
- zeitmeister
Fused told me some time ago that Cindigo keeps some things in the RAM when rerendering a scene.
I remember that i got the impression at some point, but in the latest versions it definately doesnt any more.
It would be so cool to get Indigo let the user decide wether "rebuild complete" or "export only changes" on export or rendering, you are very right.
Grüsse, zeiti
Grüsse, zeiti
Particle Support
Normal Maps
Normal Maps
- pixie
It once had a simply but powerfull hack, 'export without geometry'... very usefull to tweaking a scene.zeitmeister wrote:Fused told me some time ago that Cindigo keeps some things in the RAM when rerendering a scene.
Grüsse, zeiti
